Throttled Posted June 27, 2023 Share Posted June 27, 2023 What do think? Replace now, or wait till the service in November, at most 2000 more miles? Quote Link to comment Share on other sites More sharing options...
Tiggie Posted June 27, 2023 Share Posted June 27, 2023 I think there's loads of life left on those. I am from Yorkshire though 3 1 Quote Link to comment Share on other sites More sharing options...
Mickly Posted June 27, 2023 Share Posted June 27, 2023 What about this? Think the Newquay trip may have seen it off Quote Link to comment Share on other sites More sharing options...
Throttled Posted June 27, 2023 Author Share Posted June 27, 2023 Tread wise the tyre looks fine. It does look a bit squared off though. 1 Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted June 27, 2023 Share Posted June 27, 2023 (edited) The tyre is pretty much on the wear marker. I would get it changed asap. The pads should last until service time. Edited June 27, 2023 by fullscreenaging 1 Quote Link to comment Share on other sites More sharing options...
Bender Posted June 27, 2023 Share Posted June 27, 2023 Pads look fine, tyre is almost down to wear marker. Quote Link to comment Share on other sites More sharing options...
Yorky Posted June 27, 2023 Share Posted June 27, 2023 3 hours ago, Tiggie said: I think there's loads of life left on those. I am from Yorkshire though I think exactly the same. But so am I 1 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 27, 2023 Share Posted June 27, 2023 I would replace the tyre. The pads should last another 2k. Quote Link to comment Share on other sites More sharing options...
Bender Posted June 27, 2023 Share Posted June 27, 2023 32 minutes ago, Mississippi Bullfrog said: I would replace the tyre. The pads should last another 2k. 6k if you don't brake slot Depends on riding style as to how long you will get. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 27, 2023 Share Posted June 27, 2023 Loads on the pads! The tyre should have been replaced 500 miles ago 2 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 27, 2023 Share Posted June 27, 2023 3 hours ago, Bender said: 6k if you don't brake slot Depends on riding style as to how long you will get. I wouldn't 2k out of them. I usually wear mine out in 5k. But I tend to be heavy on the front brake. But the next service is in 2k so they would want replacing then or they won't make the next service. 1 Quote Link to comment Share on other sites More sharing options...
Bender Posted June 27, 2023 Share Posted June 27, 2023 2 hours ago, Stu said: Loads on the pads! The tyre should have been replaced 500 miles ago We don't all drive buses you know, sorry let me correct that, we don't all ride buses 2 Quote Link to comment Share on other sites More sharing options...
Throttled Posted June 28, 2023 Author Share Posted June 28, 2023 17 hours ago, Bender said: Pads look fine, tyre is almost down to wear marker. Is the wear marker in the middle of the photo and tyre, where the long tread is split by a cross piece? Quote Link to comment Share on other sites More sharing options...
Mickly Posted June 28, 2023 Share Posted June 28, 2023 18 hours ago, Stu said: Loads on the pads! The tyre should have been replaced 500 miles ago Probably, I did 950 miles over 3 days and before I started could just about detect the wear bands with my finger nail. It will be changed before being used again. 2 Quote Link to comment Share on other sites More sharing options...
Mickly Posted June 28, 2023 Share Posted June 28, 2023 3 hours ago, Throttled said: Is the wear marker in the middle of the photo and tyre, where the long tread is split by a cross piece? Indeed it is 1 Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted June 28, 2023 Share Posted June 28, 2023 The wear marker is 1mm deep. The tyre is fine in the dry, but should it rain when out on that, then the tread won’t be deep enough to displace the water efficiently and it could be squeaky bum time, so very smooth throttle needed. Quote Link to comment Share on other sites More sharing options...
Mickly Posted June 28, 2023 Share Posted June 28, 2023 33 minutes ago, fullscreenaging said: The wear marker is 1mm deep. The tyre is fine in the dry, but should it rain when out on that, then the tread won’t be deep enough to displace the water efficiently and it could be squeaky bum time, so very smooth throttle needed. Unfortunately the wear marker is worn Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted June 28, 2023 Share Posted June 28, 2023 Quote Link to comment Share on other sites More sharing options...
oldgrump Posted July 2, 2023 Share Posted July 2, 2023 Your pads are fine, plenty left on them, More than I can say about my front tyre!! Got back from a 1000 mile 3 day blast, and we had a brief rain shower!!! Quote Link to comment Share on other sites More sharing options...
