Bianco2564 Posted April 20, 2023 Posted April 20, 2023 Some fast fit tyre centre round here take them for a small fee. Quote
Pie man Posted April 20, 2023 Posted April 20, 2023 1 hour ago, Mississippi Bullfrog said: Our local tip (aka recycling centre) is staffed by ex-Gestapo rejects and they won't take any form of tyre. Our Local Tip take tyres, have you checked your local council waste recycling centre, if they do, just have the info on your phone ready to challenge. Quote
Bianco2564 Posted April 20, 2023 Posted April 20, 2023 Fitted a rear reflector to the RGV, found a scrap sheet of carbon fibre at work and fixed it behind the number plate. Repainted the gear lever and fitted a new lever rubber. 5 Quote
Mississippi Bullfrog Posted April 20, 2023 Posted April 20, 2023 56 minutes ago, Pie man said: Our Local Tip take tyres, have you checked your local council waste recycling centre, if they do, just have the info on your phone ready to challenge. The council website says no tyres of any sort. If I'm paying to get rid of them I might as well have that included with the cost of fitting them. The place where I get car tyres only charged me a fiver last time they fitted a bike tyre for me. Shame really, I'd prefer to do them myself. 1 Quote
Pie man Posted April 20, 2023 Posted April 20, 2023 6 minutes ago, Mississippi Bullfrog said: The council website says no tyres of any sort. If I'm paying to get rid of them I might as well have that included with the cost of fitting them. The place where I get car tyres only charged me a fiver last time they fitted a bike tyre for me. Shame really, I'd prefer to do them myself. Ah well, I suppose its Cheshire, county of the wealthy, unlike here, if the local tip didn't take them the local Knuckle draggers will set them alight and roll them down the streets. 2 Quote
S-Westerly Posted April 20, 2023 Posted April 20, 2023 29 minutes ago, Pie man said: Ah well, I suppose its Cheshire, county of the wealthy, unlike here, if the local tip didn't take them the local Knuckle draggers will set them alight and roll them down the streets. Here in Gloucestershire it's difficult to dispose of them.Tips won't take them as of April 1st 2023. There's a lot of scallywags flytip them or chuck em in the canal. 1 Quote
Bianco2564 Posted April 21, 2023 Posted April 21, 2023 10 hours ago, S-Westerly said: Here in Gloucestershire it's difficult to dispose of them.Tips won't take them as of April 1st 2023. There's a lot of scallywags flytip them or chuck em in the canal. It was a regular thing a few years ago on the road between Southam and Banbury to see old tyres in the hedge every 100m or so. I think the perpetrators were lobbing them out the side door of a moving van. 1 Quote
Tinkicker Posted April 21, 2023 Posted April 21, 2023 (edited) Fell victim to the air coolled two stroke tickover rattle. Fired up the DT and it sounded horrendous. Last summer at about 150 miles since rebuild and 10 or 15 heat /cold cycles, I deemed it time to do a full throttle run to check the carburation at full chat. An artfully carried out bodge by the previous owner made itself aparent as about a mile into my full throttle run, a large piece of sculpted exhaust filler blew out, the bike went immediately lean and lost 50% of its power. New exhaust found and fitted and another 50 miles under its belt before getting put away for winter. So full consternation mode. Did it sound like that before? Have I blown the piston? Is the crank ok? Pulled the barrel. Light scoring present above the ports and heavier below. The upper scoring will clear with a couple of minutes with the hone, the lower probably not. Not too concerned though. I was expecting the piston to have showed signs of a partial seizure, but no, no scores or marks of any kind. The ring gap on the original rings was about 20 thou, above max allowable, but visually looked ok. I have a new, japanese oem quality piston in stock, so tried the new rings for gap. 12 thou, the minimum allowable. Crank is fine. So looks like the rings got too hot when it went lean and gripped the cylinder wall. Subsequent running has polished away the damage to the rings, leaving them excessively worn. Of course, since I have the new piston ready, I will fit it. My hone, bore gauge and micrometers are at work, so I can't measure piston clearances, oval and taper till Monday. Hope everything is still in spec after the hone. Edited April 21, 2023 by Tinkicker 1 Quote
Steve_M Posted April 21, 2023 Posted April 21, 2023 Had new boots fitted. Michelin Road Pilot 6’s. Better wet grip and longevity (allegedly) over the Road Pilot 5’s. On previous bikes a new set of tyres have made an immediate sea change to the feel and handling of a bike. As of 15 miles of riding home, no discernible improvement. Ho hum. 4 Quote
Pie man Posted April 21, 2023 Posted April 21, 2023 16 minutes ago, Steve_M said: Had new boots fitted. Michelin Road Pilot 6’s. Better wet grip and longevity (allegedly) over the Road Pilot 5’s. On previous bikes a new set of tyres have made an immediate sea change to the feel and handling of a bike. As of 15 miles of riding home, no discernible improvement. Ho hum. I put them on the 1290 before heading off to France last year, 1600 miles later, looked like they had never been turned, excellent in the wet, well IMO. 4 Quote
onesea Posted April 21, 2023 Posted April 21, 2023 (edited) On 20/04/2023 at 19:14, Mississippi Bullfrog said: Our local tip (aka recycling centre) is staffed by ex-Gestapo rejects and they won't take any form of tyre. Tyre, old petrol, charges for rubble (2' square of plaster board that will be £10), you need to register your car reg plate prior to going (so no hire vehicles), make an appointment, arrive on time to join the qué, your trailer has to be the right size, park where instructed not near the convenient bin , you cannot recycle your oven before your fridge (no I am serious I had to take the fridge out of car to recycle an oven then put the fridge back in the car before driving 20' to recycle that). They are basically only interested in stuff they can take out of your car boot and put in the blue container to sell to car boot sale traders. That way they can say they recycle 99% of waste. What they don't accept then gets dumped in local lanes or in our case national park. https://www.advertiserandtimes.co.uk/news/amp/new-forest-rangers-despair-as-fly-tippers-strike-three-times-in-24-hours-9152941/ It still goes on. I can only guess the staff are married to the local "Medical Receptionist" or as we know them, Dr's receptionists. Then have have regular socials and conferences to find new ways to make people's lives more miserable. Back on subject: Another use for old tyres put them on the box in your front garden that you keep your lawn mower in. We bought our house and didn't look in the unlocked storage box topped with a couple of old tyres for several weeks ( expecting more junk). Then found we had a by then a much needed free lawn mower. This security measure has now successfully guarded 3 lawn mowers. Edited April 22, 2023 by onesea 3 Quote
Mississippi Bullfrog Posted April 22, 2023 Posted April 22, 2023 10 hours ago, onesea said: Tyre, old petrol, charges for rubble (2' square of plaster board that will be £10), you need to register your car reg plate prior to going (so no hire vehicles), make an appointment, arrive on time to join the qué, your trailer has to be the right size, park where instructed not near the convenient bin , you cannot recycle your oven before your fridge (no I am serious I had to take the fridge out of car to recycle an oven then put the fridge back in the car before driving 20' to recycle that). They are basically only interested in stuff they can take out of your car boot and put in the blue container to sell to car boot sale traders. That way they can say they recycle 99% of waste. What they don't accept then gets dumped in local lanes or in our case national park. https://www.advertiserandtimes.co.uk/news/amp/new-forest-rangers-despair-as-fly-tippers-strike-three-times-in-24-hours-9152941/ It still goes on. I can only guess the staff are married to the local "Medical Receptionist" or as we know them, Dr's receptionists. Then have have regular socials and conferences to find new ways to make people's lives more miserable. Back on subject: Another use for old tyres put them on the box in your front garden that you keep your lawn mower in. We bought our house and didn't look in the unlocked storage box topped with a couple of old tyres for several weeks ( expecting more junk). Then found we had a by then a much needed free lawn mower. This security measure has now successfully guarded 3 lawn mowers. Our doctor's surgery doesn't have 'receptionists' anymore. We are now directed to a 'Care Navigator'. Their role seems to remain the same, to make sure you never get to see a doctor. Our daughter lives in Wales and I was helping her clear some stuff a few weeks ago. So I went to their local tip expecting the usual extration of fingernails and several minutes of waterboarding. It was quite a shock to be greet by three blokes who were genuinely helpful and made life much more pleasant. Their recycling rate is slightly higher than our local tip so there's no need for the hostile attitude. 2 Quote
Bianco2564 Posted April 22, 2023 Posted April 22, 2023 Full day in the garage. Started by changing the oil and filter on the Kwak 250, done almost 2000 miles on it since Jan. Things are much easier with a spin on filter. Then moved onto the R1. Went to a work colleagues funeral yesterday and a group of us followed the hearse on bikes. The weather was pretty wet and we got soaked, I'm sure Carl was up there laughing at us.... It got fairly dirty so gave it a wash. First time I've riden the R1 since January, felt pretty rusty on it for a few miles but f@k does it shift when I opened it up. Next was the RGV, finished the brakes off and took the fairing off the clean it all up. Although I've never riden it in the rain, the dirt on the engine and frame was considerable. Changed the engine oil, I've only done 464 miles since the engine rebuild but that was over 5 years ago. Keep finding bits on it I want to spruce up or replace but where do you stop? 6 Quote
JRH Posted April 22, 2023 Posted April 22, 2023 On 20/04/2023 at 20:50, Stu said: Local waste recycling place takes them here “Recycling” centres in Warwickshire won’t take anything if they get away with it. Quote
Stu Posted April 22, 2023 Author Posted April 22, 2023 35 minutes ago, JRH said: “Recycling” centres in Warwickshire won’t take anything if they get away with it. It's just encouraging people to go fly tipping 1 Quote
S-Westerly Posted April 22, 2023 Posted April 22, 2023 10 minutes ago, Stu said: It's just encouraging people to go fly tipping Absolutely true. When the tip used to take tyres you never or rarely saw tyres in the hedgerows. Now it's almost every time I'm out. So now either the land owner has to or more likely the council anyway gets stuck with the costs. Daft. 2 Quote
MikeHorton Posted April 22, 2023 Posted April 22, 2023 1 hour ago, Bianco2564 said: Full day in the garage. Started by changing the oil and filter on the Kwak 250, done almost 2000 miles on it since Jan. Things are much easier with a spin on filter. Then moved onto the R1. Went to a work colleagues funeral yesterday and a group of us followed the hearse on bikes. The weather was pretty wet and we got soaked, I'm sure Carl was up there laughing at us.... It got fairly dirty so gave it a wash. First time I've riden the R1 since January, felt pretty rusty on it for a few miles but f@k does it shift when I opened it up. Next was the RGV, finished the brakes off and took the fairing off the clean it all up. Although I've never riden it in the rain, the dirt on the engine and frame was considerable. Changed the engine oil, I've only done 464 miles since the engine rebuild but that was over 5 years ago. Keep finding bits on it I want to spruce up or replace but where do you stop? Rgvs still look amazing to this day well worth all ur fettling 1 Quote
Pie man Posted April 22, 2023 Posted April 22, 2023 57 minutes ago, S-Westerly said: Absolutely true. When the tip used to take tyres you never or rarely saw tyres in the hedgerows. Now it's almost every time I'm out. So now either the land owner has to or more likely the council anyway gets stuck with the costs. Daft. Our council, for the what they are worth, have been pro active in combating fly tipping. However, they do take all waste, asbestos, tyres etc but plasterboard, the amount of checks prior takes a forever and it is banned from landfill Quote
Bianco2564 Posted April 22, 2023 Posted April 22, 2023 1 hour ago, MikeHorton said: Rgvs still look amazing to this day well worth all ur fettling Totally agree, 2 strokes race reps of this era look and sound fantastic. RGV, TZR, NSR, KRIS, RS, never see the likes of them again (for a good reason though, smoke and fuel consumption are not great features). 2 Quote
Davidtav Posted April 24, 2023 Posted April 24, 2023 Rode it. From Yorkshire to Portavadie where my boat is. Seemed to have every sort of weather including hail storm. Which was actually slightly scary as my visor completely turned white. And I was on the M6 at the time doing 70ish. Might have been the M74. Not sure … anyway I’m at my boat now and quite a nice evening 2 Quote
Davidtav Posted April 24, 2023 Posted April 24, 2023 (edited) And my new gear was great. There is a story to my new gear. So my biking partner is the local vicar. And he had been gifted some gear. From a parishioner that was learning to ride. Had bought all the gear. And fell off during his lessons. Vowed never to get on a bike again and gifted the gear to Wilf. And when I mentioned to Wilf my stuff wasn’t keeping me dry. It came to me. I do feel slightly guilty about this Edited April 25, 2023 by Davidtav 1 Quote
Mississippi Bullfrog Posted April 25, 2023 Posted April 25, 2023 20 hours ago, Davidtav said: And my new gear was great. There is a story to my new gear. So my biking partner is the local vicar. And he had been gifted some gear. From a parishioner that was learning to ride. Had bought all the gear. And fell off during his lessons. Vowed never to get on a bike again and gifted the gear to Wilf. And when I mentioned to Wilf my stuff wasn’t keeping me dry. It came to me. I do feel slightly guilty about this Never trust the local vicar. I say this with some authority on the subject. Devious buggers. They have to be to survive the job. 3 Quote
Davidtav Posted April 25, 2023 Posted April 25, 2023 I have a sneaking suspicion Mr Bullfrog that you are also a vicar. I might be wrong Quote
Davidtav Posted April 25, 2023 Posted April 25, 2023 Anyway it was some BKS kit. It isn’t crazy expensive. But yeah there were some downpours and kept me dry. So all good so far 1 Quote
Fish Posted April 25, 2023 Posted April 25, 2023 After two days of a customer doing my nut, I'll be off out for a ride after food! Quote
