James in Brum Posted May 30, 2020 Posted May 30, 2020 I need to buy a breaker bar to try to undo the nuts on the rear wheel to adjust the chain slack. Do I buy an 18inch or 24Inch? Or am I doing the wrong thing? Quote
Bender Posted May 30, 2020 Posted May 30, 2020 No idea on the torque required for your nuts , but make sure you get a good bar, long is good you can add a tube to it for real stubborn things but not if it's made of cheese.Bought one from halfords years ago, went to take wheel of wife's focus, bit of effort and away it went, or so I thought, nope I just ripped the 1/2 drive out of the end knuckle, straight back it went followed by an argument over misuse, Errr I used it to take the wheel of that car. Quote
Tiggie Posted May 30, 2020 Posted May 30, 2020 I'd go for the bigger one My first breaker bar that I still use on occasion was an old dumbbell bar that fits over my wrench (I know all the issues and reasons why not to do this before anyone chimes in!!) Quote
Gerontious Posted May 30, 2020 Posted May 30, 2020 I got a Bahco as it was on offer on Amazon. 390mm length. 1/2" driveSo, a little over 15" in old money. And makes short work of the 100nm bolt on the rear wheel. Quote
Guest Richzx6r Posted May 30, 2020 Posted May 30, 2020 I'd go for 8ft if you can you can never have a long enough bar for leverage Quote
Tiggie Posted May 30, 2020 Posted May 30, 2020 [mention]Richzx6r[/mention] when I moved into my house about 5 years ago I found a 5ft piece of scaffold down the side of the garage. Was well pleased even though I haven't needed to use it yet Quote
Mississippi Bullfrog Posted May 30, 2020 Posted May 30, 2020 Go for the 24 inch. You don’t always need it but if you do then you’ve got the leverage. Otherwise it just makes life easier the rest of the time. Quote
fastbob Posted May 30, 2020 Posted May 30, 2020 I'd go for the bigger one My first breaker bar that I still use on occasion was an old dumbbell bar that fits over my wrench (I know all the issues and reasons why not to do this before anyone chimes in!!) Ditto , I also have a weight bar that fits over my wrench handle . Quote
fastbob Posted May 30, 2020 Posted May 30, 2020 @Richzx6r when I moved into my house about 5 years ago I found a 5ft piece of scaffold down the side of the garage. Was well pleased even though I haven't needed to use it yet This is getting silly . I also have a piece of scaffolding pole . Mine is only 4ft though . I had some crazy idea that I could undo the 50 mm clutch hub nut on my GSXR by putting my trusty table leg through the back wheel and standing on the scaffolding that was slipped over a giant wrench . No chance . I borrowed a big Snap-on electric impact gun in the end . Quote
Tiggie Posted May 30, 2020 Posted May 30, 2020 I too have borrowed a snap-on impact gun before Not for bike though it was to do the cv joint on my very old car at the time. Those bolts were not coming off until I used that gun Quote
geofferz Posted May 31, 2020 Posted May 31, 2020 My 18 inchx1/2 inch halfords breaker bar in just fine for my 190nm torque rear axle bolt FYI. I'm sure more is better but you'll probs get away with a shorter one if needs be. Quote
James in Brum Posted May 31, 2020 Author Posted May 31, 2020 I went for the biggest Halfords pro one. 24” i think. It worked anyway. Quote
Mississippi Bullfrog Posted June 2, 2020 Posted June 2, 2020 I went for the biggest Halfords pro one. 24” i think. It worked anyway. Halfords Pro stuff is good. I once broke a socket, doing something silly to be fair, it was replaced no questions asked.The rest of their stuff I've had for years and it's survived several car rebuilds. Quote
Mickly Posted June 2, 2020 Posted June 2, 2020 I’ve got a 2’6” long 3/4” drive breaker bar & a set of adaptors to go with it, don’t know the make, but it was £15 from an autojumble & haven’t managed to break it yet, despite trying very hard !! i.e. 16 stone of Mickly jumping up & down on it while removing the gearbox sprocket nut on the Trophy. Quote
Guest Richzx6r Posted June 2, 2020 Posted June 2, 2020 I recently nearly twisted off the end of a 3/8 extension bar and I wasn't putting much pressure through it Quote
Ian Frog Posted June 2, 2020 Posted June 2, 2020 I recently nearly twisted off the end of a 3/8 extension bar and I wasn't putting much pressure through it I think possibly the 3/8 bit is the clue.If it`s going to take a bit of oomph 1/2 or more I would suggest.I can be a ham fisted twat believe me but I havent bothered my 2ft bar even with 3ft of scaffold pole added when trying to get the nuts off a mates tractor wheel.CheersIan Quote
Guest Richzx6r Posted June 2, 2020 Posted June 2, 2020 It twisted under maybe 90lb ft was undoing a wheel nut on a mates car and it just shear twisted at the very end where it goes in to the socket Quote
Ian Frog Posted June 2, 2020 Posted June 2, 2020 It twisted under maybe 90lb ft was undoing a wheel nut on a mates car and it just shear twisted at the very end where it goes in to the socket Wow fair play you are obviously a proper knuckle dragger or are in training for Britain`s strongest man LOLCheersIan Quote
Bender Posted June 2, 2020 Posted June 2, 2020 I recently nearly twisted off the end of a 3/8 extension bar and I wasn't putting much pressure through it The 1/2 one I destroyed was made of cheese. Quote
Ian Frog Posted June 2, 2020 Posted June 2, 2020 I recently nearly twisted off the end of a 3/8 extension bar and I wasn't putting much pressure through it The 1/2 one I destroyed was made of cheese. Do you remember the make so we can all avoid it ?Manufacturers of crap deserve naming and shaming so we can all avoid them.CheersIan Quote
Bender Posted June 2, 2020 Posted June 2, 2020 Was one from Halfords, wasn't professional one but other than that no idea, went straight to machine mart bought one took wheel off without additional leverage. Quote
Ian Frog Posted June 2, 2020 Posted June 2, 2020 I believe it was a hilka one Twat !Good job mine is spelt in capitals.The hilka you speak of is obviously a Chinese rip off lol.CheersIan Quote
