Mickly Posted November 5, 2021 Author Posted November 5, 2021 6 hours ago, Mississippi Bullfrog said: The other thing to mention is that are the bolts stretch bolts? If so then you'll need new ones when re-assembling. They are one use only. That's particularly so with the bolts used these days when the final tightening is by degrees rather than torque. I am aware of this & have new bolts … not cheap!! Quote
Mickly Posted November 5, 2021 Author Posted November 5, 2021 The liners are out & cleaned up again along with their seats. I thought I would test fit the head without the liners & gasket to ensure it sits flush & guess what?? Correct - it doesn’t My suspicion is that I’ve fitted one or more of the dowels on the piss !! To be continued …. 1 Quote
Mickly Posted November 11, 2021 Author Posted November 11, 2021 Right, back on track. Managed to get the dowels sorted & the cyl head sitting flat ( without the liners or gasket in place ) Good job I removed the head as I realised that I’d omitted to fit this: fixed cam chain guide .. whoops. Smaller beads of sealant added to the liners & head refitted. The gaps either side of the head are now satisfactory with no way of squeezing the smallest of feeler gauges in. Now to fit the cam shafts. 4 Quote
Mickly Posted November 13, 2021 Author Posted November 13, 2021 T.14 mark on the Ignition rotor aligned with the centre of the pick up coil. Cam shafts placed with cam chain over them & arrows on the sprockets pointing inwards Cam shims and journals oiled, Cam caps oiled, fixings oiled & hand tightened to just nipped up then torqued up to 10 N/M in a cross cross pattern - this is not a lot & I could have easily over tightened by hand. I believe @fastbob has previously stated that this is a critical time to use a torque wrench. Chain tensioner to be fitted … @onesea said the spring should be replaced as it’s a weak point - Spec says it should be 73.5mm long. I resisted the urge to stretch it So new spring to be ordered - thus ends play until it arrives. Quote
billy sugger Posted November 13, 2021 Posted November 13, 2021 56 minutes ago, Mickly said: T.14 mark on the Ignition rotor aligned with the centre of the pick up coil. Cam shafts placed with cam chain over them & arrows on the sprockets pointing inwards Cam shims and journals oiled, Cam caps oiled, fixings oiled & hand tightened to just nipped up then torqued up to 10 N/M in a cross cross pattern - this is not a lot & I could have easily over tightened by hand. I believe @fastbob has previously stated that this is a critical time to use a torque wrench. Chain tensioner to be fitted … @onesea said the spring should be replaced as it’s a weak point - Spec says it should be 73.5mm long. I resisted the urge to stretch it So new spring to be ordered - thus ends play until it arrives. Can't you use some kind of upgraded spring, like you can with clutches? Quote
onesea Posted November 13, 2021 Posted November 13, 2021 1 hour ago, billy sugger said: Can't you use some kind of upgraded spring, like you can with clutches? Hopefully he’s ordered from sprint parts they are said to be the best, by the FB group gods. https://www.triumphparts.co.uk/product/cam-chain-tensioner-spring/ PS mine was not to different when I changed it. When built you can just put them in and out but rebuilding like you are I would wait… Quote
Mickly Posted November 13, 2021 Author Posted November 13, 2021 52 minutes ago, onesea said: Hopefully he’s ordered from sprint parts they are said to be the best, by the FB group gods. https://www.triumphparts.co.uk/product/cam-chain-tensioner-spring/ PS mine was not to different when I changed it. When built you can just put them in and out but rebuilding like you are I would wait… Yep, Sprint Manufacturing Quote
Mickly Posted November 13, 2021 Author Posted November 13, 2021 2 hours ago, billy sugger said: Can't you use some kind of upgraded spring, like you can with clutches? Maybe, but I wouldn’t want to put any extra stress on the cam chain. Quote
fastbob Posted November 13, 2021 Posted November 13, 2021 6 hours ago, Mickly said: T.14 mark on the Ignition rotor aligned with the centre of the pick up coil. Cam shafts placed with cam chain over them & arrows on the sprockets pointing inwards Cam shims and journals oiled, Cam caps oiled, fixings oiled & hand tightened to just nipped up then torqued up to 10 N/M in a cross cross pattern - this is not a lot & I could have easily over tightened by hand. I believe @fastbob has previously stated that this is a critical time to use a torque wrench. Chain tensioner to be fitted … @onesea said the spring should be replaced as it’s a weak point - Spec says it should be 73.5mm long. I resisted the urge to stretch it So new spring to be ordered - thus ends play until it arrives. That's the one ! It's amazing how inadequate the small amount of torque feels but that's the way it is . Quote
fastbob Posted November 13, 2021 Posted November 13, 2021 3 hours ago, Mickly said: Maybe, but I wouldn’t want to put any extra stress on the cam chain. The spring will be fine . It's not there to exert a lot of force . If the spring ceases to be effective then the cam chain should have been replaced ages ago . Having said that , I did fit a manual tensioner to my last ER5 just for a laugh . Quote
Mickly Posted January 3, 2022 Author Posted January 3, 2022 Latest update & question New cam chain tensioner spring fitted. Now to check the clearance between the cam lobes & the shims. When the company that did the machine work said they took 4thou off the top of the valve stems to compensate for the material taken off when the head was skimmed so I could use the old shims - which seemed odd, maybe I miss heard & they meant that it was to compensate for the material removed when they cut the valve seats which would make more sense…. Anyway despite what they said all the clearances had closed up so a lot of new shims were required, some of the gaps were so tight so couldn’t get a 0.04 mm gauge in, which was the smallest I’d got so a new set of feeler gauges were bought & finally all the gaps are now within tolerance. The question I’ve got is whether it is any use doing a compression test at this stage … if so then I’m in the sh*t (again) as there’s hardly any compression at the moment!! 1 Quote
Bender Posted January 3, 2022 Posted January 3, 2022 3 hours ago, Mickly said: Latest update & question New cam chain tensioner spring fitted. Now to check the clearance between the cam lobes & the shims. When the company that did the machine work said they took 4thou off the top of the valve stems to compensate for the material taken off when the head was skimmed so I could use the old shims - which seemed odd, maybe I miss heard & they meant that it was to compensate for the material removed when they cut the valve seats which would make more sense…. Anyway despite what they said all the clearances had closed up so a lot of new shims were required, some of the gaps were so tight so couldn’t get a 0.04 mm gauge in, which was the smallest I’d got so a new set of feeler gauges were bought & finally all the gaps are now within tolerance. The question I’ve got is whether it is any use doing a compression test at this stage … if so then I’m in the sh*t (again) as there’s hardly any compression at the moment!! Not until its been run in, rings are not bedded in yet never mind valves. 1 1 Quote
fastbob Posted January 3, 2022 Posted January 3, 2022 Second that , let it all bed in before worrying about a compression test . 1 Quote
Bianco2564 Posted January 4, 2022 Posted January 4, 2022 (edited) What makes you concerned about no compression? How are you testing it? Edited January 4, 2022 by Bianco2564 Quote
Mickly Posted January 5, 2022 Author Posted January 5, 2022 14 hours ago, Bianco2564 said: What makes you concerned about no compression? How are you testing it? With a compression gauge screwed into the spark plug socket & turning it over by hand with a socket on the end of the crank … which in retrospect is a plainly stupid idea at the slow turn gives time for the air to escape past the rings, 1 Quote
Bender Posted January 5, 2022 Posted January 5, 2022 1 hour ago, Mickly said: With a compression gauge screwed into the spark plug socket & turning it over by hand with a socket on the end of the crank … which in retrospect is a plainly stupid idea at the slow turn gives time for the air to escape past the rings, Yea that's not going to fly Quote
Mississippi Bullfrog Posted January 8, 2022 Posted January 8, 2022 On 05/01/2022 at 11:56, Mickly said: With a compression gauge screwed into the spark plug socket & turning it over by hand with a socket on the end of the crank … which in retrospect is a plainly stupid idea at the slow turn gives time for the air to escape past the rings, Not stupid, just perhaps a tad over-optimistic. Nothing wrong with being optimistic. Quote
Mickly Posted May 21, 2022 Author Posted May 21, 2022 Hiya Right, it’s been a while … Engine is back in Not with out much wrangling & use of a Pludger To line up the mounting holes. As previously mentioned, the aftermarket exhaust fixings were a bit too close to the swinging arm, also the gear change mechanism was scraping the LH silencer, so I got a couple of bits stainless tube ( had them flared so didn’t need to use the expansion collets that came with the pipes & looked shit … Here they are fitted. Now there is satisfactory clearance between to the swinging arm and gear change mechanism Just received these: I was gonna fit the originals but having sat in the wrong spec of oil for a while, I reckon they might have been impregnated so cleaning would not be sufficient. So after soaking in the correct spec of oil over night they are now fitted. Clutch lever was rock hard but after a little bleeding it seems to be working fine. Now the sun is shining & the keys to the Speedtriple are calling 2 Quote
Mickly Posted May 21, 2022 Author Posted May 21, 2022 Having zipped up the casings I filled it with oil &? BOLLOCKS !! Persistent drip from the sump to block gasket Quote
Keeper96 Posted May 25, 2022 Posted May 25, 2022 On 21/05/2022 at 20:38, Mickly said: Having zipped up the casings I filled it with oil &? BOLLOCKS !! Persistent drip from the sump to block gasket Not the end of the world dropping the sump bud. I fitted an overhauled engine from a 3rd party at work and when we started it up it was leaking from a timing case plug… only way to repair it was drop the engine again Quote
Mickly Posted May 26, 2022 Author Posted May 26, 2022 9 hours ago, Keeper96 said: Not the end of the world dropping the sump bud. I fitted an overhauled engine from a 3rd party at work and when we started it up it was leaking from a timing case plug… only way to repair it was drop the engine again True, just have to remove the exhaust which means removing the radiator- no real biggie but still a pain in the arse. Quote
onesea Posted May 26, 2022 Posted May 26, 2022 14 minutes ago, Mickly said: True, just have to remove the exhaust which means removing the radiator- no real biggie but still a pain in the arse. Have you tried backing off the nuts and reseating in situ? Its a large gasket and sometimes it’s just amateur of getting the bedding right. Quote
Mickly Posted May 26, 2022 Author Posted May 26, 2022 Just now, onesea said: Have you tried backing off the nuts and reseating in situ? Its a large gasket and sometimes it’s just amateur of getting the bedding right. Thanks for the advice, but the sumps already off Quote
Mickly Posted May 27, 2022 Author Posted May 27, 2022 I’m taking the sump off I noticed that the two central bolts weren’t winding out … My heart sunk & sure enough the threads were stripped - I’d torqued them up and at the time thought that they couldn’t possibly tight enough - luckily I didn’t do them by feel or I might have stripped the lot !! So I purchased a 6mm Helicoil kit However my drill was too long to fit vertically under the bike After a bit of head scratching I ground some flats onto the shank if the drill so it would hold in my tap wrench and slowly ream out the holes, periodically ensuring it was going in at 90* to the surface. Note the tape around the drill indicating the depth of the hole. A very slow process but ultimately effective Holes with Helicoil marked up Now to refit the sump 3 Quote
Mickly Posted May 27, 2022 Author Posted May 27, 2022 Sump is now fitted with a smear of gasket sealant & no sign of any stripped threads, I’ll fill it with oil tomorrow .. if @Mississippi Bullfrogwould say a prayer for me I would appreciate it 2 Quote
