jedibiker Posted January 22, 2022 Posted January 22, 2022 Hello all. I wasnt sure if this was a pitstop chat or normal so please move if not. So my bandit is running lovely, but Im noticing im getting less miles to a full tank.. so cost per litre isnt a factor. Ive used e5 and e10 and it doesnt change much if at all. But I used to get over 200miles to a tank. and with that give it some beans as well as cruise. Lately pretty much cruise with the odd little blast and get 165 before 1 bar flashes, and I usually fill up as soon as poss of within 10 miles. So a good drop off 20-30 miles per tank.. Should I be looking for an issue at all. Or is it the fuel thats changed... only had a tank of e5 since the e10 change Quote
Mississippi Bullfrog Posted January 22, 2022 Posted January 22, 2022 Fuel consumption is usually higher in the winter but check for any signs of leakage and that nothing is binding. Salt can corrode brake sliders causing a bit of drag. 2 Quote
MikeHorton Posted January 22, 2022 Posted January 22, 2022 I found marginal differences between e5 and e10 but this is now greater in the winter. As said winter riding makes a difference 1 Quote
Mr Fro Posted January 22, 2022 Posted January 22, 2022 1 hour ago, MikeHorton said: I found marginal differences between e5 and e10 but this is now greater in the winter. As said winter riding makes a difference It's coz the air is fikka innit. 5 Quote
Mississippi Bullfrog Posted January 23, 2022 Posted January 23, 2022 9 hours ago, Mr Fro said: It's coz the air is fikka innit. Like few of us on here. 1 3 Quote
husoi Posted January 24, 2022 Posted January 24, 2022 How far is next service? Spark plugs could be a factor. Air filter is another key factor. But all depends how new/old they are. Quote
Stu Posted January 24, 2022 Posted January 24, 2022 It will solely be the winter months taking its toll if its an injected bike then it will stay on the cold map for longer and sometimes may never get off the cold map 1 Quote
Mississippi Bullfrog Posted January 24, 2022 Posted January 24, 2022 I see nobody has pointed out that your average biker on entering winter makes careful preparation for the colder weather by ensuring they have an extra layer of blubber to insulate them through the cold winter months. This is achieved by the scoffing of pies and other delicacies which turn your summer biker into a much larger and heavier version. 2 2 Quote
MikeHorton Posted January 24, 2022 Posted January 24, 2022 6 hours ago, Stu said: It will solely be the winter months taking its toll if its an injected bike then it will stay on the cold map for longer and sometimes may never get off the cold map I might buy my bike a nice fleecy coat like the dog has when he goes for a walk. Like the dog ill make sure it's exhaust area is clear, may solve the issue. Could be one for dragons den Quote
Stu Posted January 24, 2022 Posted January 24, 2022 18 minutes ago, MikeHorton said: I might buy my bike a nice fleecy coat like the dog has when he goes for a walk. Like the dog ill make sure it's exhaust area is clear, may solve the issue. Could be one for dragons den Many moons ago people used to block the front of radiators to restrict the air flow to help cars warm up and stay warm 1 Quote
MikeHorton Posted January 24, 2022 Posted January 24, 2022 2 hours ago, Stu said: Many moons ago people used to block the front of radiators to restrict the air flow to help cars warm up and stay warm I'm sure my uncle used to do that on his Vauxhall chevette Quote
Stu Posted January 24, 2022 Posted January 24, 2022 Just now, MikeHorton said: I'm sure my uncle used to do that on his Vauxhall chevette Probably My dad used to do it on his Land Rover 1 Quote
keith1200rs Posted January 24, 2022 Posted January 24, 2022 2 hours ago, Stu said: Many moons ago people used to block the front of radiators to restrict the air flow to help cars warm up and stay warm That was before they discovered electricity. The fan was running continuously even in the middle of winter. Quote
Stu Posted January 24, 2022 Posted January 24, 2022 Just now, keith1200rs said: That was before they discovered electricity. The fan was running continuously even in the middle of winter. The airflow alone through the front in the cold weather is more than enough to stop a motor heating properly The fan didn't help matters thats for sure Quote
linuxrob Posted January 24, 2022 Posted January 24, 2022 Bandits are sensitive to air filter condition. Give it a blow out. Most likely the cold weather but check the back brake, they a prone to seizing up. 2 pot calipers at the front are OK. Quote
Mississippi Bullfrog Posted January 24, 2022 Posted January 24, 2022 3 hours ago, Stu said: Many moons ago people used to block the front of radiators to restrict the air flow to help cars warm up and stay warm We did it with all our cars. If you were poor it was a cardboard box, if you were posh you used tinfoil. 1 1 Quote
Bender Posted January 24, 2022 Posted January 24, 2022 8 minutes ago, Mississippi Bullfrog said: We did it with all our cars. If you were poor it was a cardboard box, if you were posh you used tinfoil. We all did betwixt viscous fans and faulty stats it was a necessity so you didn't freeze and you could get the ice off the inside of the screen as your car always leaked and damp carpets created extra moisture. Quote
Bianco2564 Posted January 24, 2022 Posted January 24, 2022 4 hours ago, Stu said: Many moons ago people used to block the front of radiators to restrict the air flow to help cars warm up and stay warm In my AA book of the car 1970 edition, it shows installing a radiator blind on an Austin 1100. 1 1 Quote
Mississippi Bullfrog Posted January 25, 2022 Posted January 25, 2022 9 hours ago, Bianco2564 said: In my AA book of the car 1970 edition, it shows installing a radiator blind on an Austin 1100. Is that the kind like a window roller blind? You had a cord you fed into the car so you could raise and lower it as necessary without needing to open the bonnet. This was akin to rocket science back then. 1 Quote
keith1200rs Posted January 25, 2022 Posted January 25, 2022 15 hours ago, Stu said: The airflow alone through the front in the cold weather is more than enough to stop a motor heating properly The fan didn't help matters thats for sure That's probably true, and probably simply radiated heat from the engine. I had a Honda Prelude many years ago and in winter if I didn't reach 50mph it wouldn't provide enough heat to warm the interior. I guess the water thermostat stayed shut. My wife's Fiesta turbo is the opposite - after a few miles at slow speed it is belting heat out into the cabin. Quote
husoi Posted January 25, 2022 Posted January 25, 2022 I remember my mother's '76 mini having the air intake movable so in winter you would point it to the engine block while in summer would be turn away. Quote
JRH Posted January 25, 2022 Posted January 25, 2022 3 hours ago, husoi said: I remember my mother's '76 mini having the air intake movable so in winter you would point it to the engine block while in summer would be turn away. Likewise with my 60’s vintage Vauxhall. Quote
Bianco2564 Posted January 26, 2022 Posted January 26, 2022 On 25/01/2022 at 07:21, Mississippi Bullfrog said: Is that the kind like a window roller blind? You had a cord you fed into the car so you could raise and lower it as necessary without needing to open the bonnet. This was akin to rocket science back then. Dug my book out the loft. On another page it tells you how to upgrade your car with fitting a screen washer or indicators. 2 Quote
Mississippi Bullfrog Posted January 27, 2022 Posted January 27, 2022 I can remember the leap from trafficators to indicators on our A35 van. They were still connected to a big bakelite switch in the middle of the dash. Quote
Bender Posted January 27, 2022 Posted January 27, 2022 On 25/01/2022 at 12:03, keith1200rs said: That's probably true, and probably simply radiated heat from the engine. I had a Honda Prelude many years ago and in winter if I didn't reach 50mph it wouldn't provide enough heat to warm the interior. I guess the water thermostat stayed shut. My wife's Fiesta turbo is the opposite - after a few miles at slow speed it is belting heat out into the cabin. The opposite I would say, thermostats were crap back then, honda was a pretty good car, thermostat will have been stuck open, they a operate and restrict flow depending on temp, stuck open you just froze, you used to have a winter Stat option but few people would swap them, most just drove round freezing Quote
