daveinlim Posted August 21, 2022 Share Posted August 21, 2022 (edited) Doing a little check over on the bike and saw a stone bedded in the front tyre. There's good amount of thread and the tyres not squared off. The lighting make it look a bit square. The hole is about 1.5 or 2mm deep Should I have this looked at or potentially replaced. Or am I being a bit paranoid. Edited August 21, 2022 by daveinlim Quote Link to comment Share on other sites More sharing options...
Ian Frog Posted August 21, 2022 Share Posted August 21, 2022 Pic might help ! Cheers Ian Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 21, 2022 Share Posted August 21, 2022 I assume you mean 1.5 or 2.0mm rather than metres. In which case that's less than the tread pattern depth. So long as it's in the treaded area that should not be a problem....but as above, a picture would help. Quote Link to comment Share on other sites More sharing options...
daveinlim Posted August 21, 2022 Author Share Posted August 21, 2022 3 hours ago, Ian Frog said: Pic might help ! Cheers Ian Yeah I think you're right about that. Added now. Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted August 21, 2022 Share Posted August 21, 2022 That’ll be fine. 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted August 21, 2022 Share Posted August 21, 2022 You will be surprised how thick tyres are! Quote Link to comment Share on other sites More sharing options...
bonio Posted August 22, 2022 Share Posted August 22, 2022 Its fine. I used to fret over these too. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 22, 2022 Share Posted August 22, 2022 Congratulations, you have installed a new wear indicator in your tyre. When it disappears it's time to change your tyre. 2 Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted August 22, 2022 Share Posted August 22, 2022 8 hours ago, Stu said: You will be surprised how thick tyres are! I think I'm thicker than a tyre 1 Quote Link to comment Share on other sites More sharing options...
onesea Posted August 22, 2022 Share Posted August 22, 2022 1 hour ago, MikeHorton said: I think I'm thicker than a tyre Just remember they are designed to roll along the road picking up the odd stone your not. I wouldn't worry about the tyre. 1 Quote Link to comment Share on other sites More sharing options...
daveinlim Posted August 22, 2022 Author Share Posted August 22, 2022 Thanks everyone. Tyre will stay put for now. And as Mississippi Bulldog said I have a new wear indicator now Quote Link to comment Share on other sites More sharing options...
nickjaxe Posted August 22, 2022 Share Posted August 22, 2022 The rubber part of a tyre give little strength..its the reinforcing under the rubber that's the strength. I 1 1 Quote Link to comment Share on other sites More sharing options...
