RideWithStyles Posted May 11, 2024 Posted May 11, 2024 (edited) 16-19ltrs Edited May 15, 2024 by RideWithStyles Quote
Geordie Oldie Posted May 11, 2024 Posted May 11, 2024 (edited) 3 hours ago, RideWithStyles said: 16-19ltrs depending on specific bike. bikes can be very fugal with if ridden lightly in the right circumstance's though 6 ltrs used for 40miles is 30mpg so you mustn't be pottering about? I filled it up before I set off. Also it was 80 miles round trip.coming back was quicker but still best part of an hour. Edited May 11, 2024 by Geordie Oldie Quote
S-Westerly Posted May 11, 2024 Posted May 11, 2024 (edited) 11 hours ago, Geordie Oldie said: Went out for a proper ride on my Hornet, filled her up, it must be the first time in 30 years I have put petrol in a bike, maybe longer. Only took 6 litres, I will have to check the volume of the tank. Rode down the A1 from Northumberland to my mates house in Durham, rather foolishly I had forgotten what the A1 is like on a Friday afternoon ( retired) it was at a virtually standstill and difficult to filter due to narrow lanes and road works. I always avoid the A1 on busy days or times unless I've absolutely no choice. Going from my dad's in Morpeth to my daughter's in Barnard Castle the A68 isn't a bad way and you can cut across the moors etc. Of course if he's on the flat bit of Durham near the coast you're screwed. Edited May 11, 2024 by S-Westerly Quote
Geordie Oldie Posted May 11, 2024 Posted May 11, 2024 1 hour ago, S-Westerly said: I always avoid the A1 on busy days or times unless I've absolutely no choice. Going from my dad's in Morpeth to my daughter's in Barnard Castle the A68 isn't a bad way and you can cut across the moors etc. Of course if he's on the flat bit of Durham near the coast you're screwed. Spennymoor, I thought about the A68. Quote
S-Westerly Posted May 11, 2024 Posted May 11, 2024 Just now, Geordie Oldie said: Spennymoor, I thought about the A68. A68 to Firtree then cut across to Bishop and then Spennymoor. Done it myself and parts of the A68 are a lot of fun. Still have slow cars etc but plenty of chances to pass. 1 Quote
Tinkicker Posted May 12, 2024 Posted May 12, 2024 (edited) Float gaskets arrived saturday lunchtime, so fitted those and fitted the carbs back on the bike. Plugged in my remote fuel tank and propped it up high to get a good head of fuel. No leaks and no overflows. Started bike to get fuel pump pressure. No leaks and no overflows. Left remote tank plugged in to keep more head pressure in the system than the bikes own fuel tank, locked shed and had beer. This morning, looked in. Remote tank level had not changed, oil level had not changed and no sign of overflowing float vents. Then calibrated the gauges on cylinder 1 and balanced the carbs. Hate it. Whoever designed that carb rack and adjuster setup is a damnable sadist. You cannot even see the screws, everything has to be done by feel and in a small space, surrounded by sharp, red hot bits of engine. Not a place you want to be sticking your hand in. My right paw is a bit of a burned, bruised mess this afternoon. But carbs are balanced to within specified tolerance. Fuel tank is back on the bike and connected up. Fuel is off. I have discovered that with seat removed and a long JIS screwdriver, you can turn the tap on and off by using the tap lever securing screw to operate the tap. Lesson learned. From now on the default setting for that tap when in the shed is OFF. Carbs now within spec and a nice smooth idle. They were not far out in any case. My initial bench setup worked very well. Always check the calibration of the gauges against each other before starting to synch the carbs. Edited May 12, 2024 by Tinkicker 5 Quote
S-Westerly Posted May 12, 2024 Posted May 12, 2024 4 hours ago, Tinkicker said: Float gaskets arrived saturday lunchtime, so fitted those and fitted the carbs back on the bike. Plugged in my remote fuel tank and propped it up high to get a good head of fuel. No leaks and no overflows. Started bike to get fuel pump pressure. No leaks and no overflows. Left remote tank plugged in to keep more head pressure in the system than the bikes own fuel tank, locked shed and had beer. This morning, looked in. Remote tank level had not changed, oil level had not changed and no sign of overflowing float vents. Then calibrated the gauges on cylinder 1 and balanced the carbs. Hate it. Whoever designed that carb rack and adjuster setup is a damnable sadist. You cannot even see the screws, everything has to be done by feel and in a small space, surrounded by sharp, red hot bits of engine. Not a place you want to be sticking your hand in. My right paw is a bit of a burned, bruised mess this afternoon. But carbs are balanced to within specified tolerance. Fuel tank is back on the bike and connected up. Fuel is off. I have discovered that with seat removed and a long JIS screwdriver, you can turn the tap on and off by using the tap lever securing screw to operate the tap. Lesson learned. From now on the default setting for that tap when in the shed is OFF. Carbs now within spec and a nice smooth idle. They were not far out in any case. My initial bench setup worked very well. Always check the calibration of the gauges against each other before starting to synch the carbs. Braver man than me. 1 Quote
peepae Posted May 13, 2024 Posted May 13, 2024 On 04/05/2024 at 00:05, Joe85 said: Well, i managed to get it up (relatively) straight. I quite like it. What jeans are those? They look quite good. Quote
S-Westerly Posted May 13, 2024 Posted May 13, 2024 Changed the end can from this: to this: I think it looks better. Unfortunately the utterly hideous catalyser is even more visible. Why can manufacturers not make a cat system that looks anything better than ugly and goes downhill from that? 4 Quote
Simon Davey Posted May 13, 2024 Posted May 13, 2024 7 minutes ago, S-Westerly said: Changed the end can from this: to this: I think it looks better. Unfortunately the utterly hideous catalyser is even more visible. Why can manufacturers not make a cat system that looks anything better than ugly and goes downhill from that? Looks very smart, I really like the heat shield. You're only seeing a tiny bit more of the cat, it's just more noticeable because the new can is smaller than the original. How about some matt black fire paint? The kind they spray on log burners etc, that would hide the cat. Something like this (although this is a paint) https://www.machinemart.co.uk/p/clarke-sp5-heat-resistant-stove-paint-matt-b/ 2 Quote
S-Westerly Posted May 13, 2024 Posted May 13, 2024 45 minutes ago, Simon Davey said: Looks very smart, I really like the heat shield. You're only seeing a tiny bit more of the cat, it's just more noticeable because the new can is smaller than the original. How about some matt black fire paint? The kind they spray on log burners etc, that would hide the cat. Something like this (although this is a paint) https://www.machinemart.co.uk/p/clarke-sp5-heat-resistant-stove-paint-matt-b/ That's actually not a bad idea. A paint on version would work as I don't want overspray and with no garage I don't really want to dismantle the system. 2 Quote
RideWithStyles Posted May 13, 2024 Posted May 13, 2024 (edited) sa Edited May 15, 2024 by RideWithStyles 1 Quote
skyrider Posted May 13, 2024 Posted May 13, 2024 9 hours ago, S-Westerly said: Changed the end can from this: to this: I think it looks better. Unfortunately the utterly hideous catalyser is even more visible. Why can manufacturers not make a cat system that looks anything better than ugly and goes downhill from that? the joys of modern bike ownership classics never had these hideous things 1 Quote
Gerontious Posted May 13, 2024 Posted May 13, 2024 15 minutes ago, skyrider said: the joys of modern bike ownership classics never had these hideous things it’s a choice if the bikes designer to make these things obviously visible. There is no need to - the one on my GS was invisible, unless I got down in my hands and knees. And as that was one of the first cats on a bike that appeared in 1993. It seems ridiculous and just plain lazy for this to be an issue 30 years later. 1 Quote
curlylegend Posted May 13, 2024 Posted May 13, 2024 1 hour ago, skyrider said: the joys of modern bike ownership classics never had these hideous things You do wonder though, don't you ? Modern motorcycles engines are very efficient. But a Boeing airliner taking off will burn through over 500gallons of fuel, and how many planes take off and land every day around London for example ? Compared to this, motorcycles are unlikely to be doing much damage to the environment. Vegan and vegetarian flatulence probably contributes as much pollution as motorcycles. 4 1 Quote
Mississippi Bullfrog Posted May 14, 2024 Posted May 14, 2024 19 hours ago, S-Westerly said: Changed the end can from this: to this: I think it looks better. Unfortunately the utterly hideous catalyser is even more visible. Why can manufacturers not make a cat system that looks anything better than ugly and goes downhill from that? That does look a whole lot better. I hate those huge end cans on modern bikes. Re the cat....one reason I'm a fan of the Bobber is that the cat is very cleverly hidden. There are then two dummy covers that hide where the real exhaust enters and exits the cat. It makes look like a straight through system. So it can be done. Black high temp paint works and will certainly hide the cat visually. I use it on the CBF downpipes which are mild steel (Honda you cheapskates) but you need to repaint a couple of times a year as it doesn't survive the underside of motorcycles for long. 2 1 Quote
Nick the wanderer Posted May 14, 2024 Posted May 14, 2024 9 hours ago, curlylegend said: Vegan and vegetarian flatulence probably contributes as much pollution as motorcycles. Ha Haar... I bet your farts smell of roses.. 1 Quote
S-Westerly Posted May 14, 2024 Posted May 14, 2024 Prepped it for a thrash up to Northumberland tomorrow to see my Dad. He's having a bit of a wobble but he's 93 so it's not a surprise. Given the weather I'm probably looking at a motorway grind. 1 Quote
Trooper74 Posted May 15, 2024 Posted May 15, 2024 (edited) On 14/05/2024 at 11:30, S-Westerly said: Prepped it for a thrash up to Northumberland tomorrow to see my Dad. He's having a bit of a wobble but he's 93 so it's not a surprise. Given the weather I'm probably looking at a motorway grind. When you get to Doncaster move on to the A19 … massive delays north of Donnie on the A1 ..the A19 is a nice ride all the way to the Tyne tunnel …. fast A road Edited May 15, 2024 by Trooper74 Quote
S-Westerly Posted May 15, 2024 Posted May 15, 2024 1 hour ago, Trooper74 said: When you get to Doncaster move on to the A19 … massive delays north of Donnie on the A1 ..the A19 is a nice ride all the way to the Tyne tunnel …. fast A road Cut over to the M62 and looped back. Those roadworks over the Aire (?) have been going on for ages. No idea when they'll be finished. When I head south again I'll probably go over to the Western side. 1 Quote
Tinkicker Posted May 17, 2024 Posted May 17, 2024 Finished refitting the VFR bodywork this morning. A slight delay caused by the need to order and replace some perished rubber grommets. Also replaced some of the duller fairing "button" bilts with titanium ones. Should last a bit longer than the plating on the 4 year old OEM ones. 7 Quote
Simon Davey Posted May 17, 2024 Posted May 17, 2024 We really need a "wow" emoji, the only giveaway that it's not a new bike, is the tax disk. Gorgeous looking machine. 1 1 Quote
Tinkicker Posted May 17, 2024 Posted May 17, 2024 4 minutes ago, Simon Davey said: We really need a "wow" emoji, the only giveaway that it's not a new bike, is the tax disk. Gorgeous looking machine. Thank you kind sir. I retire in 5 years and it will see the use it has been rebuilt for then. Just now it is just marking time with a couple of hundred miles a year. 3 Quote
peepae Posted May 17, 2024 Posted May 17, 2024 Final quote for BMW service - (32k miles hasn't been serviced since 21k) unfortunately has to be dealer because all the mechanics in my area have waiting lists of weeks, and my rear tyre is right above the legal limit at about 1.7/8mm It's gonna be an expensive monday. Quote
Simon Davey Posted May 17, 2024 Posted May 17, 2024 That'll see you right for a couple of years, depending on mileage. 2 Quote
