lancesilver Posted August 16, 2023 Share Posted August 16, 2023 Hi, I have a neco 1 xs scooter that keeps cutting out on me every 10-20 seconds, it was brand new in May and has done 600miles, oil and fuel seem fine any ideas on what I can do? Need the bike for work and my town has no bike garages Quote Link to comment Share on other sites More sharing options...
husoi Posted August 16, 2023 Share Posted August 16, 2023 If it's brand new, it's no brainer. Warranty. Quote Link to comment Share on other sites More sharing options...
Steve_M Posted August 16, 2023 Share Posted August 16, 2023 52 minutes ago, husoi said: If it's brand new, it's no brainer. Warranty. And courtesy bike while it’s being sorted. Quote Link to comment Share on other sites More sharing options...
Old-codger Posted August 16, 2023 Share Posted August 16, 2023 You need to get back onto the supplying dealer and tell them what is wrong with it and get them to collect it and fix it. Look up your rights concerning the consumer rights act 2015 so you know what to say if they try to fob you off. 1 Quote Link to comment Share on other sites More sharing options...
lancesilver Posted August 16, 2023 Author Share Posted August 16, 2023 Thanks everyone, dealership can't pick up till Monday hence why I was seeing if there was anything I can check on my end Quote Link to comment Share on other sites More sharing options...
Bender Posted August 16, 2023 Share Posted August 16, 2023 1 hour ago, lancesilver said: Thanks everyone, dealership can't pick up till Monday hence why I was seeing if there was anything I can check on my end Not worth the risk, they will use any excuse to get out of warranty, as long as you have petrol, it's turned on. Quote Link to comment Share on other sites More sharing options...
onesea Posted August 17, 2023 Share Posted August 17, 2023 13 hours ago, Bender said: Not worth the risk, they will use any excuse to get out of warranty, as long as you have petrol, it's turned on. Got to agree here, I know it seems we are being unhelpful. The fault could be allot of things. I am trusting it had ran ok for first 600 miles you have not made any recent mods and it has not been dropped etc. or been used in rain for first time? Regardless the dealer is the best point of contact and be firm with them to make it repaired quickly. There are horror stories out there. Only check I would do is check the manual and do a start as per manual, incase it’s not a simple error. Who hasn’t tried to start the bike with kill switch on? Or the immobiliser switched on? Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted August 17, 2023 Share Posted August 17, 2023 Wonder if the tank breather is trapped of kinked? If you can open the fuel tank does tons of air rush back into the tank? Then close it back, and start it up again. does it cut out much later on but still does cut out?? Most likely is that but to test would be to leave the tank cap ajar and start it up again and leave it on idle, if it stays running beyond the last time its definitely the brether hose. Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted August 17, 2023 Share Posted August 17, 2023 If so generally two small thinest black pipes coming from the bottom of the tank and follow them, the one you want will lead to the very bottom of the bike pointing to the floor most likly between the engine and the swing arm. See if there are any kinks or trapps. crap might have clogged it, you can clear it with a low pressure air or wd40 from the little hole in the top of the tank in the there will tvery small hole to the side next to the inlet that you fill with petrol . Quote Link to comment Share on other sites More sharing options...
Solution lancesilver Posted August 19, 2023 Author Solution Share Posted August 19, 2023 Just wanted to say it went back to the dealership and a bullet connector had busted so they fixed that and it's running perfectly now thanks everyone x 4 Quote Link to comment Share on other sites More sharing options...
Tiggie Posted August 19, 2023 Share Posted August 19, 2023 Good news Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted August 19, 2023 Share Posted August 19, 2023 Brill result and the dealer did something!!! Only asking cos i sus question everthing and learn from it.... why did a bullet connector fail!?any which one? Hmmmmm. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 20, 2023 Share Posted August 20, 2023 10 hours ago, RideWithStyles said: Brill result and the dealer did something!!! Only asking cos i sus question everthing and learn from it.... why did a bullet connector fail!?any which one? Hmmmmm. Maybe it was shot? 1 Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted August 20, 2023 Share Posted August 20, 2023 3 months old and 600miles?? that really sus. did it just have a service prior? Quote Link to comment Share on other sites More sharing options...
Tiggie Posted August 20, 2023 Share Posted August 20, 2023 A pretty common failure for chinese scoots/motorbikes. I've had to fix a few for friends or similar and it's usually electric related rather than anything to do with the engine. Melted headlight connectors was the last one I had to do! Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted August 20, 2023 Share Posted August 20, 2023 Yeah also often run the loom far too short and tight around the bike. Gave my old bike the "cant switch off the indicators that went into variable disco lights settings while i was about 100 miles away from home" it got there attention but confused the crap out of car drivers at the same time. Just wanted to know just for interest, knowledge and future reference, it would be good to know which one it was... Quote Link to comment Share on other sites More sharing options...
