oudafuq Posted March 23 Share Posted March 23 So after a few hours riding the triumph , I’m noticing severe pain in my left hand to the point I’m struggling to pull the clutch and in turn losing a lot of confidence in riding. I’ve never experienced this before on any other bike and I’m wondering if it’s the clutch or me im pretty gutted as I was so looking forward to being back out on 2 wheels any thoughts please Quote Link to comment Share on other sites More sharing options...
husoi Posted March 23 Share Posted March 23 You're not alone on that. Mostly when riding the pan I have to stop to have a rest on my left hand. I sometimes use one of the exercise springs that you squeeze and gets your hand and wrist stronger. It helps a bit but not the cure for it 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted March 23 Share Posted March 23 New gloves by any chance? This can sometimes be the cause Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted March 23 Share Posted March 23 (edited) When I came back to biking after a long period out I found that the first couple of weeks my left hand used to cramp up but after a bit it stopped and these days ino longer have that problem at least. Edited March 23 by S-Westerly 1 Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted March 23 Share Posted March 23 Only use the clutch to move off, using clutch control, down shift and when the bike comes to a stop. The rest of the time employ clutch less shifting. This will save your hand a bit from pulling the clutch in so much. Some clutches are stiffer than others also. 1 Quote Link to comment Share on other sites More sharing options...
Capt Sisko Posted March 23 Share Posted March 23 (edited) It might be worth trying a 'Crampbuster' palm rest to give your hand/wrist an easier time. They're primarily designed as a throttle rest / sort of cruise control and as such most are right handed, but you can get a LH one with the rest on the other side. Link below. I use one on the clutch side all the time and they got me through several Iron But SS1,000 that would have otherwise hand my hands aching. Crampbuster Edited March 23 by Capt Sisko 1 1 Quote Link to comment Share on other sites More sharing options...
bonio Posted March 23 Share Posted March 23 What about going to a dealership, the kind of place where they have a load of secondhand bikes (Lings in Harleston for example), and trying the clutch on any 1050s they've got in stock. Could be the clutch cable needs lubricating? But searching on the internet seems to show others complaining about the clutch being heavy on that bike. People say they get used to it. 1 Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted March 23 Share Posted March 23 (edited) simply what hand size are you? how wide or narrow are your shoulders, elbows and hands to the bars? id doubt the lever is adjustable (a real fing bug bear of mine). are the bars/clip ons eventually centred? so many times they aint from the factory let alone a normal mech. do you have a old injury that's making it harder for you? are you having to over reach or doing extra movement to go get the lever? so if the lever is too high or if too low into relation to your hand, your either having to move you hand behind the grip to allow the fingers to get height for over the top lever grip (get the lever) or rolling forward to reach for it and lowering your fingers to over bear them. just a thought. Edited March 23 by RideWithStyles 1 Quote Link to comment Share on other sites More sharing options...
oudafuq Posted March 24 Author Share Posted March 24 16 hours ago, Stu said: New gloves by any chance? This can sometimes be the cause No, but the ones I wore aren’t the best as the liners are loose . now have a new pair to test out 1 Quote Link to comment Share on other sites More sharing options...
oudafuq Posted March 24 Author Share Posted March 24 10 hours ago, Capt Sisko said: It might be worth trying a 'Crampbuster' palm rest to give your hand/wrist an easier time. They're primarily designed as a throttle rest / sort of cruise control and as such most are right handed, but you can get a LH one with the rest on the other side. Link below. I use one on the clutch side all the time and they got me through several Iron But SS1,000 that would have otherwise hand my hands aching. Crampbuster Ordered, do you get points for challenge 100 for mentioning @Hoggs 2 Quote Link to comment Share on other sites More sharing options...
oudafuq Posted March 24 Author Share Posted March 24 8 hours ago, RideWithStyles said: simply what hand size are you? how wide or narrow are your shoulders, elbows and hands to the bars? id doubt the lever is adjustable (a real fing bug bear of mine). are the bars/clip ons eventually centred? so many times they aint from the factory let alone a normal mech. do you have a old injury that's making it harder for you? are you having to over reach or doing extra movement to go get the lever? so if the lever is too high or if too low into relation to your hand, your either having to move you hand behind the grip to allow the fingers to get height for over the top lever grip (get the lever) or rolling forward to reach for it and lowering your fingers to over bear them. just a thought. Bars are stock for the bike, it does have adjustable levers tho. I’m not quite sure of the pros/cons of them I always adjust the levers so my wrists aren’t bending to grab the levers , shoe one on here taught me that many’s years ago! I’ll be popping out on it later to see if the different gloves are any help Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted March 24 Share Posted March 24 (edited) 24 minutes ago, oudafuq said: Bars are stock for the bike, it does have adjustable levers tho. I’m not quite sure of the pros/cons of them I always adjust the levers so my wrists aren’t bending to grab the levers , shoe one on here taught me that many’s years ago! I’ll be popping out on it later to see if the different gloves are any help Adjust the clutch lever for minimum travel. You want the clutch to disengage/engage a couple of cm into the first bit of movement so you don’t have to pull the lever all the way in. You will only be using the first one or two knuckles of your fingers instead of your whole hand. Edited March 24 by fullscreenaging 2 Quote Link to comment Share on other sites More sharing options...
Phil1 Posted March 24 Share Posted March 24 Ensure you've got the angle of the lever right too, if you're having to twist your wrist all the way back it will soon become painful. It might just need angling further down. Check full lock to lock afterwards too to make sure you don't move it to a position where cables/hoses are rubbing on anything. 1 Quote Link to comment Share on other sites More sharing options...
Phil1 Posted March 24 Share Posted March 24 47 minutes ago, fullscreenaging said: Adjust the clutch lever for minimum travel. You want the clutch to disengage/engage a couple of cm into the first bit of movement so you don’t have to pull the lever all the way in. You will only be using the first one or two knuckles of your fingers instead of your whole hand. I'd throw some amount of caution with that one. It's easy to adjust it too far and not have the clutch fully engaged even when it's released, you'll ruin the clutch in no time. 1 Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted March 24 Share Posted March 24 42 minutes ago, Phil1 said: I'd throw some amount of caution with that one. It's easy to adjust it too far and not have the clutch fully engaged even when it's released, you'll ruin the clutch in no time. I agree, but you can feel this and adjust accordingly. 2 Quote Link to comment Share on other sites More sharing options...
oudafuq Posted March 25 Author Share Posted March 25 Managed a few hours out yesterday with my mate i didn’t suffer so bad so I’m hoping, luring the cable, adjusting the lever and different gloves may have helped. I’m also doing some stretching exersices to see if that helps. so far so good 5 Quote Link to comment Share on other sites More sharing options...
Simon Davey Posted March 25 Share Posted March 25 @oudafuq I had quite unpleasant upper back pain when I first started riding again (just a couple of months ago) and the guys on here said to just relax. The more I ride, the more the "fun" comes back, and the more I relax. Get very little aches now, and I've only got 6 hours under my belt since I last rode 24 years ago. Good luck, and I hope the aches and pains lessen with each ride. 2 Quote Link to comment Share on other sites More sharing options...
husoi Posted March 25 Share Posted March 25 I found that a supplement of magnesium has greatly improved my continuous joint pain 1 1 Quote Link to comment Share on other sites More sharing options...
oudafuq Posted March 25 Author Share Posted March 25 3 minutes ago, husoi said: I found that a supplement of magnesium has greatly improved my continuous joint pain I’m on vitamin B and cod liver oil 1 Quote Link to comment Share on other sites More sharing options...
husoi Posted March 25 Share Posted March 25 Some cheapish cod liver oil capsules use outdated pil and are as good as not having them. Magnesium can be taken with pretty much any other supplements and have no known side effects Quote Link to comment Share on other sites More sharing options...
skyrider Posted March 25 Share Posted March 25 iboprufen & levomenthol anti-inflammatory gel 1 Quote Link to comment Share on other sites More sharing options...
bonio Posted March 25 Share Posted March 25 2 hours ago, husoi said: I found that a supplement of magnesium has greatly improved my continuous joint pain I don't think I have a continuous joint. 2 Quote Link to comment Share on other sites More sharing options...
curlylegend Posted March 25 Share Posted March 25 2 hours ago, husoi said: Magnesium can be taken with pretty much any other supplements and have no known side effects Just a point, some magnesium supplements can loosen your bowels. Magnesium Citrate was a nightmare for me, Magnesium Chloride made me nauseous but Magnesium Bisglycinate seems to do the trick. I take it to relieve irritating cramping in my legs at night. Another thing to look forward to when you get old. And I can now watch Buffy the Vampire Slayer without having lascivious thoughts. 3 Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted March 26 Share Posted March 26 Is there a point to watching Buffy without lascivious thoughts? I thought that was the whole point of it. 2 Quote Link to comment Share on other sites More sharing options...
husoi Posted March 26 Share Posted March 26 If it was only Buffy.... Quote Link to comment Share on other sites More sharing options...
