She runs.. Had a little issue with neutral sensor wire, unrelated to the install but replaced that anyway. Apart from a few tweeks she should be fine.. There is a little tick noise but its yet to run properly and I need to top oil up and nip up exhaust after its had a warm up etc. Cam chain tensioner seemed ok, chain was tight but could be a thing for the future if tick continues. But happy enough for now.. cheers for the support. (sounds more of a tick on phones than the mac)
https://www.dropbox.com/s/0e1h4gzz89ouao6/20210328_154258.mp4?dl=0
  • Like 3
12 hours ago, Stu said:
Happy ending :thumb:
Just in time for summer
Is that the same kind of happy ending you get from a thai massage :lol:
  • Haha 1
Probably an idea to sell it before the next oil filter change . 😉
  • 2 weeks later...
wont need to if your brass nut advice works :)
In all my years both as a bike owner and as a parts and accessories salesman , I have never encountered or heard of an exhaust system that interferes with the removal of the oil filter . Purely out of curiosity , do you have any idea what make this thing is ?
No but after searching the net it seems many forums are riddled with issues on the fazer with aftermarket pipes. It seems some go down straighter than needed and leave a tiny bit of room that the filter would not fit through even if you did manage to unscrew it.  its not like its a great exhaust either as it rusts badly. My bandit has stainless pipes and I can get to the filter easy.
Hi @fastbob, Remember the old Piper Systems, the one for the Yamaha XJ550 you had two problems 1 filter couldn't be removed, 2 don't try riding over speed bumps!!!!! Ground out totally!!
And also some early Vance & Hines systems, when you had the large filter under engine, as on Kawasaki Z1100R, like this one. 4 into 2 went either side, 4 into 1 went across filter housing!!
  • Like 2
I honestly can't remember what the arrangement was on my Z 1000 ST .
I didn`t remember the ST with a swoopy tank I was thinking of the green slab side released at the same time as the first Z1300.
Glad I hadn`t met that one I would have wanted it!
Cheers
Ian
Cheers
Ian
Well spotted . This bike was heavily modified using an earlier tank , side panels , tail and seat .
38 minutes ago, fastbob said:
Yours look like it was the tank, panels, mudguard etc off the LTD, or CSR model. And the ST model was shaft drive, hence I don't think they sold very well!
