potatobroxd Posted June 14, 2021 Share Posted June 14, 2021 So i lost a key.. and im planning to order a new one. Its just a normal key (not a smart one) so i was wondering if you would need a dealer to do it or you could just cut the key anywhere? Bike has an immobiliser so im not sure if it changes anything. tia! Quote Link to comment Share on other sites More sharing options...
Stu Posted June 14, 2021 Share Posted June 14, 2021 Factory fitted immobiliser? 1 Quote Link to comment Share on other sites More sharing options...
Gerontious Posted June 14, 2021 Share Posted June 14, 2021 (edited) Unless you have a separate fob for the immobiliser.. the 'off-on' doo-dah will be in the key itself. you will need to buy a genuine key and take it to a dealership to have it matched to your bike. its not a cheap process. A genuine key for my own bike costs £75+ and then add to that the cost of 'labour' for the key to be synced with the bike.. another £35 for a half hours labour. a key with a built in immobiliser transponder will look something like this.. with a chunky fob. It contains a chip, very much like the chip in a credit/debit card. . Edited June 14, 2021 by Gerontious 1 Quote Link to comment Share on other sites More sharing options...
KiwiBob Posted June 14, 2021 Share Posted June 14, 2021 (edited) If its an ordinary key and you have one for them to copy then Timpsons should be able to cut it. They've done them for my Cg125 and ER5 but they are old bikes. Edited June 14, 2021 by KiwiBob 1 1 Quote Link to comment Share on other sites More sharing options...
husoi Posted June 14, 2021 Share Posted June 14, 2021 Donno about Kawa's but Honda would need a Honda key if fitted with HISS 1 Quote Link to comment Share on other sites More sharing options...
Mr Fro Posted June 14, 2021 Share Posted June 14, 2021 My advice is get a genuine key blank and have a local cutter do it. I've got a bike that came with a key cut from a "near enough" blank and it needs a good bit of wiggling to get it to work. The original it came with is fine though. 1 Quote Link to comment Share on other sites More sharing options...
potatobroxd Posted June 14, 2021 Author Share Posted June 14, 2021 3 hours ago, Stu said: Factory fitted immobiliser? Yes, its from factory, although my key looks identical to a ninja 300 with no imobiliser 2 hours ago, Gerontious said: Unless you have a separate fob for the immobiliser.. the 'off-on' doo-dah will be in the key itself. you will need to buy a genuine key and take it to a dealership to have it matched to your bike. its not a cheap process. A genuine key for my own bike costs £75+ and then add to that the cost of 'labour' for the key to be synced with the bike.. another £35 for a half hours labour. a key with a built in immobiliser transponder will look something like this.. with a chunky fob. It contains a chip, very much like the chip in a credit/debit card. . Mine seems like a normal slim key with no chip in it luckily! 1 hour ago, Mr Fro said: My advice is get a genuine key blank and have a local cutter do it. I've got a bike that came with a key cut from a "near enough" blank and it needs a good bit of wiggling to get it to work. The original it came with is fine though. Thanks, thought i could save some cash doing it outside the dealer Quote Link to comment Share on other sites More sharing options...
Stu Posted June 14, 2021 Share Posted June 14, 2021 If it has an immobiliser from factory but no extra fob then I suspect you will need a key with a new chip in Its not always doom and gloom though as not all bikes require a visit to the dealers to code the key in Have a read of the owners manual and see if it mentions anything in there 1 Quote Link to comment Share on other sites More sharing options...
skyrider Posted June 14, 2021 Share Posted June 14, 2021 7 hours ago, KiwiBob said: If its an ordinary key and you have one for them to copy then Timpsons should be able to cut it. They've done them for my Cg125 and ER5 but they are old bikes. cobbler's usually cut keys as well Quote Link to comment Share on other sites More sharing options...
Pie man Posted June 14, 2021 Share Posted June 14, 2021 9 hours ago, potatobroxd said: So i lost a key.. and im planning to order a new one. Its just a normal key (not a smart one) so i was wondering if you would need a dealer to do it or you could just cut the key anywhere? Bike has an immobiliser so im not sure if it changes anything. tia! by what means are you ordering another one, who off and where from. Do you have a key number, do you have another key to copy from, if so and its chipped it is sometimes possible to have it cloned Quote Link to comment Share on other sites More sharing options...
Jerry1111 Posted June 19, 2021 Share Posted June 19, 2021 On 14/06/2021 at 16:00, Stu said: If it has an immobiliser from factory but no extra fob then I suspect you will need a key with a new chip in Long time ago I had an N-reg A4 and needed a spare key. Went to Timpsons and they cut me the new key and also programmed the immobilizer chip with a box they had. 1 Quote Link to comment Share on other sites More sharing options...
TimR Posted June 19, 2021 Share Posted June 19, 2021 If you have breakdown cover see if you have a Key Assist cover or some home insurance will have something . Quote Link to comment Share on other sites More sharing options...
Doofa57 Posted July 5, 2021 Share Posted July 5, 2021 (edited) when i lose my keys i search for them Edited July 5, 2021 by Doofa57 Quote Link to comment Share on other sites More sharing options...
