Throttled Posted September 10, 2023 Share Posted September 10, 2023 The Oxford heated grip, left-hand side, spins, the glue has clearly given up. Any recommendations? Quote Link to comment Share on other sites More sharing options...
billy sugger Posted September 10, 2023 Share Posted September 10, 2023 Oddly enough, so has mine. I think the heat has got to it Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted September 10, 2023 Share Posted September 10, 2023 Mine has done the same for a few years now. I’ve tried all sorts with no good results. I think it’s because it’s directly onto metal and when the grip gets hot it heats the bar up and softens the glue. It’s harder to spin when the grip is not on. Quote Link to comment Share on other sites More sharing options...
onesea Posted September 10, 2023 Share Posted September 10, 2023 Hight temperature contact adesive? Silicone sealant? Quote Link to comment Share on other sites More sharing options...
fredc Posted September 11, 2023 Share Posted September 11, 2023 sikaflex might work Quote Link to comment Share on other sites More sharing options...
megaross Posted September 11, 2023 Share Posted September 11, 2023 Any superglue made for high temps. The glue provided is junk. Quote Link to comment Share on other sites More sharing options...
Fish Posted September 11, 2023 Share Posted September 11, 2023 I did hear an old skool thing of adding sugar into the glue which is meant to help, but most likely talking crap again. Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted September 11, 2023 Share Posted September 11, 2023 Renthanal is pretty good and abit like gorilla glue, but you do need to use alot. hair spray is good as it doesn't break down the same as glues but you need to work really fast and it to be a tight fit in the first place. only thing about the silicone sealant is it will be easy to get off the bar but youll only beable to cut it off the grip if you make a hash of it to refit it... Fish isnt too far off wrong, sugar and salt were mainly ingredients in oldschool super glue, there was another house hold ingredient added but I can't remember just now. Quote Link to comment Share on other sites More sharing options...
Throttled Posted September 11, 2023 Author Share Posted September 11, 2023 Some sort of silicone glue, rather than superglue, makes sense, as silicone glue is more forgiving and less likely to get all over the place. I have gone with "K2 High Temperature Silicone 350°C Red Tube 85g", based on Amazon reviews, but it was cheaper to buy off ebay. Quote Link to comment Share on other sites More sharing options...
husoi Posted September 11, 2023 Share Posted September 11, 2023 (edited) Gasket seal will do the trick. Resist to high temperature and will resist water ingress. Water is the main cause of glue failure. Not sure how hairspray will work with water. old school guys would use hairspray to help sliding the grips into place and when dried will glue it. Edited September 11, 2023 by husoi Quote Link to comment Share on other sites More sharing options...
skyrider Posted September 11, 2023 Share Posted September 11, 2023 how about gorilla glue they are always shouting how good it is on telly Quote Link to comment Share on other sites More sharing options...
husoi Posted September 11, 2023 Share Posted September 11, 2023 48 minutes ago, skyrider said: how about gorilla glue they are always shouting how good it is on telly Why you want to glue your TV? 1 Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted September 11, 2023 Share Posted September 11, 2023 (edited) Do you remember those old tvs that weighed a ton and needed a massive cabinet to sit them on?? it was good To stop the cracks in the units when tvs had projected tubes? Edited September 11, 2023 by RideWithStyles Quote Link to comment Share on other sites More sharing options...
skyrider Posted September 11, 2023 Share Posted September 11, 2023 5 hours ago, RideWithStyles said: Do you remember those old tvs that weighed a ton and needed a massive cabinet to sit them on?? it was good To stop the cracks in the units when tvs had projected tubes? do you mean those monster silver things ? Quote Link to comment Share on other sites More sharing options...
onesea Posted September 11, 2023 Share Posted September 11, 2023 7 hours ago, Throttled said: Some sort of silicone glue, rather than superglue, makes sense, as silicone glue is more forgiving and less likely to get all over the place. I have gone with "K2 High Temperature Silicone 350°C Red Tube 85g", based on Amazon reviews, but it was cheaper to buy off ebay. Silicone by it's nature is great resistant. I have seen an exhaust on a bike sealed on with bathroom silicone 12 months later was still good. "Most silicones have an operating temperature from -60°C up to +230°C." I am guessing any will do. 1 Quote Link to comment Share on other sites More sharing options...
