Guest Posted July 2, 2020 Share Posted July 2, 2020 I've been trying to get our garage sorted and whilst it was fairly empty I was thinking of doing something with the floor. Its old bare concrete at the moment, and gets dusty,hard to clean plus I find screws and the like blend in well when dropped. In my ideal world I would be able to make it look like a laboratory but the real world dictates other things. So who out there has painted or coated their garage floor and do you have a product to recommend? It's about 32m2 in total to cover.Been looking at epoxy two pack coatings like thishttps://www.taindustrialpaints.co.uk/shop/non-slip-two-pack-epoxy-floor-paint/?attribute_pa_size=5l&attribute_pa_2pk-ns-colours=08-e-51-golden-yellowI had a look at resincoat but that's too spendy. Are the bog standard floor paints any good or cheap rubbish that flake off as soon as you look at them? Also recommendations on colours? I like the idea of yellow or light blue, something light and easy to see stuff when I drop it. Quote Link to comment Share on other sites More sharing options...
manxie49 Posted July 2, 2020 Share Posted July 2, 2020 I painted mine, never again! I used floor paint recommended for garages, followed the instructions, prepped the floor, put two coats on, It looked good for a couple of years then started to flake. Once it started to flake everything that I had sat on the floor would get covered, I used to get covered in it when I was kneeling down, Any wind blowing through the garage would chuck it all up in the air, it was a nightmare. I ended up buying some cheap, interlocking, hard rubber matting from B&Q, I bought it just to cover up the flaky paint but it seems to do a pretty good job.Not sure if it was just crap paint that I used or the floor wasn't thoroughly cleaned that caused the problems but I personally wouldn't do it again, I read reviews some time after doing it where people had the same problem as I did. If you do it I would definitely recommend taking the time to search for a good quality paint and then have a look at the reviews. Quote Link to comment Share on other sites More sharing options...
Bender Posted July 2, 2020 Share Posted July 2, 2020 I sealed mine with waterproof pva, it's kept dust down, hasn't peeled but it is prone to abrasion damage but so is paint, upside it's cheap. Quote Link to comment Share on other sites More sharing options...
exportmanuk Posted July 2, 2020 Share Posted July 2, 2020 I covered mine in a plastic garage floor covering from Costco was about £130 per roll ( I used 2 as its a double garage) pattern on it looks like metal decking plate.Had it down for a couple of years or so and no problem easy to clean not been damaged by the bike stand. does the jobIt seems to have gone up quite a bit now £ 189 https://www.costco.co.uk/Tyres-Automotive/Garage/Garage-Flooring/G-Floor-75-x-17ft-23-x-52M-Floor-Protector/p/112281 Quote Link to comment Share on other sites More sharing options...
bonio Posted July 2, 2020 Share Posted July 2, 2020 Don't do what I did:1. Ran out of paint half way through job2. Rushed to Lowestoft to buy a second can3. Placed in passenger footwell. Drove home.4. Braked...you can guess the restWe spend 5 hours cleaning the car out. Fortunately the stuff was water-soluble. Quote Link to comment Share on other sites More sharing options...
skyrider Posted July 2, 2020 Share Posted July 2, 2020 is stuff called floor tread still going thats what we painted one of our shed floors with years ago and it is still good Quote Link to comment Share on other sites More sharing options...
Stu Posted July 2, 2020 Share Posted July 2, 2020 I just stuck a carpet down Quote Link to comment Share on other sites More sharing options...
Mickly Posted July 2, 2020 Share Posted July 2, 2020 I just stuck a carpet down H’mm carpet would be great, in that m6 nuts wouldn’t roll / bounce off into oblivion, but could also hide spikey or slimey Things that can be knelt on.Also carpet can harbour moisture. Quote Link to comment Share on other sites More sharing options...
husoi Posted July 2, 2020 Share Posted July 2, 2020 There are several cementious composites that will do the trick far better than paint.You want to spend a bit on quality if you don't want to have it coming out.You can also consider epoxy resin. there are several videos on youtube showing how it's done and won't be too expensive when you consider how long it lasts.Self-leveling concrete:https://www.screwfix.com/p/mapei-ultraplan-3240-self-levelling-compound-25kg/4959F?tc=DA3&ds_kid=92700048793315993&ds_rl=1249416&gclid=CjwKCAjwi_b3BRAGEiwAemPNU7PjiqafPOEbiAOqPgZmU43WKi2lWqlk_qEXNJOmdXe86rhI7Lm6UxoCL_QQAvD_BwE&gclsrc=aw.dsEpoxy resinhttps://www.ecfibreglasssupplies.co.ukCall these guys, they are the most helpful bunch you can find and the cheapest in the market. They are the ones I used for the carbon fibre for my project. Quote Link to comment Share on other sites More sharing options...
Marino Posted July 2, 2020 Share Posted July 2, 2020 Depend on budget, but anything half decent will go 500 plus for 30 m2 Quote Link to comment Share on other sites More sharing options...
Marino Posted July 2, 2020 Share Posted July 2, 2020 There are several cementious composites that will do the trick far better than paint.You want to spend a bit on quality if you don't want to have it coming out.You can also consider epoxy resin. there are several videos on youtube showing how it's done and won't be too expensive when you consider how long it lasts.Self-leveling concrete:https://www.screwfix.com/p/mapei-ultraplan-3240-self-levelling-compound-25kg/4959F?tc=DA3&ds_kid=92700048793315993&ds_rl=1249416&gclid=CjwKCAjwi_b3BRAGEiwAemPNU7PjiqafPOEbiAOqPgZmU43WKi2lWqlk_qEXNJOmdXe86rhI7Lm6UxoCL_QQAvD_BwE&gclsrc=aw.dsEpoxy resinhttps://www.ecfibreglasssupplies.co.ukCall these guys, they are the most helpful bunch you can find and the cheapest in the market. They are the ones I used for the carbon fibre for my project. Epoxy, not so easy at least not first time and difficult to prepare surface. We do it on board ships all the time, not easy at all.But yes looks business and easy to maintain Quote Link to comment Share on other sites More sharing options...
Guest Posted July 2, 2020 Share Posted July 2, 2020 Carpet is Nogoer. Entrance to garage is off a byway so likely to bring dirt and mud in so needs to be easily cleanable. Quote Link to comment Share on other sites More sharing options...
Marino Posted July 2, 2020 Share Posted July 2, 2020 https://www.bigdug.co.uk/mega-deals-c411/single-garage-interlocking-floor-tile-set-mega-deal-p18846 Quote Link to comment Share on other sites More sharing options...
Stu Posted July 2, 2020 Share Posted July 2, 2020 I just stuck a carpet down H’mm carpet would be great, in that m6 nuts wouldn’t roll / bounce off into oblivion, but could also hide spikey or slimey Things that can be knelt on.Also carpet can harbour moisture. I also have a hoover Quote Link to comment Share on other sites More sharing options...
Tiggie Posted July 2, 2020 Share Posted July 2, 2020 Do you do your welding on the carpet [mention]Stu[/mention] ?!! Quote Link to comment Share on other sites More sharing options...
Guest Posted July 2, 2020 Share Posted July 2, 2020 Depend on budget, but anything half decent will go 500 plus for 30 m2 Definitely not that much. The link I put is a two part epoxy coating, comes in about £100 which is probably cheap and not so good but might do the job. Quote Link to comment Share on other sites More sharing options...
Stu Posted July 2, 2020 Share Posted July 2, 2020 Do you do your welding on the carpet @Stu ?!! No I also have some foam anti fatigue mats I keep forgetting to lift up so just melt those Quote Link to comment Share on other sites More sharing options...
Tiggie Posted July 2, 2020 Share Posted July 2, 2020 I need to weld proof my shed before there is a burny accident Looking at a welding blanket or similar Quote Link to comment Share on other sites More sharing options...
Guest Posted July 2, 2020 Share Posted July 2, 2020 I need to weld proof my shed before there is a burny accident Looking at a welding blanket or similar Asbestos is what you want. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted July 2, 2020 Share Posted July 2, 2020 [mention]goat[/mention] I don't do a lot of welding really so was thinking of the welding blanket so i could just roll it up out of the way when not needed rather than lining floor. If I did a lot then it would make more sense Other option being to invest in a TIG but I think thats getting way ahead of my needs Quote Link to comment Share on other sites More sharing options...
Stu Posted July 2, 2020 Share Posted July 2, 2020 [mention]Tiggie[/mention] I think [mention]goat[/mention] was pulling your pisser Quote Link to comment Share on other sites More sharing options...
Tiggie Posted July 2, 2020 Share Posted July 2, 2020 Aargh!! As a mod I should be untouchable Awaiting the "this wouldn't of happened to six as a mod" comments that will be incoming Quote Link to comment Share on other sites More sharing options...
JRH Posted July 3, 2020 Share Posted July 3, 2020 I need to weld proof my shed before there is a burny accident Looking at a welding blanket or similar Quote Link to comment Share on other sites More sharing options...
husoi Posted July 3, 2020 Share Posted July 3, 2020 https://www.bigdug.co.uk/mega-deals-c411/single-garage-interlocking-floor-tile-set-mega-deal-p18846 Don't forget you will have to apply a self-leveling grout before you install this flooring.£18/m2 doesn't sound too bad if the quality is good Not too sure how you clean a oil spill on it, there is no indication of chemical resistance so I will assume there is none.Thinking about brake fluid and the likes I won't be too sure it will cope with it that well.Still not a bad value and easy fitting. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 3, 2020 Share Posted July 3, 2020 https://www.bigdug.co.uk/mega-deals-c411/single-garage-interlocking-floor-tile-set-mega-deal-p18846 Don't forget you will have to apply a self-leveling grout before you install this flooring.£18/m2 doesn't sound too bad if the quality is good Not too sure how you clean a oil spill on it, there is no indication of chemical resistance so I will assume there is none.Thinking about brake fluid and the likes I won't be too sure it will cope with it that well.Still not a bad value and easy fitting. I had a look at some similar ones called duramat which are apparently resistant to most chemicals and solvents. Would be expensive to do the whole garage but I guess with the tiles I could do a smaller section and then do more later. Quote Link to comment Share on other sites More sharing options...
