2 hours ago, dynax said:
No spares currently available for Xena, so for the time being I will keep my rides short and only for important duties.
I did however replace the innertubes on my bicycle and washed it in the shower you gotta love having a wet room :lol:
So at least if Xena is out of commission I still have some transport, trust this to happen since selling Bridget :lol:
What exactly is the issue ?
I will take a photo in bit just having a kebab, but I might have found a fix for it :thumb:
It's this rubber grommet type thing what has split, it fits inside a spring which is behind the impeller.
The fix I have in mind is to use some heat shrink to bond over it, nothing to lose by trying :thumb:
Gotta say the gospel pass was lovely and I am sure I could bore you rigid with pics but if you get the chance and haven't been there before please do!!
Cheers
Ian
  • Like 3
Cheers
Ian
You will have to do a new thread when you get chance with a bit of a write up :thumb:
  • Like 2
Cheers Stu
I will do something.
We are moving to an Airbnb in Stratford in the morning.
As it is on the canal and near pubs I will take more pics and update when we get back if you want?
Cheers
Ian
  • Like 3
8 minutes ago, Ian Frog said:
Cheers Stu
Cheers
Ian
Yeah that would be good
Just a thread with a run down of your trip with any decent roads/routes you went with pics would be great
It gives people an idea if they are thinking of a trip :D
I think I have fixed it, didn't have a big enough diameter heatshrink so an alternative needed to be found, and believe it or not I used the neck of a balloon and the glue from a puncture repair kit. I have it all back together in the casing ready to be fitted back on the bike, I will do that in the morning and get it filled back up with fluids and take it for a test ride :thumb:
  • Like 2
Posted (edited)
42 minutes ago, Ian Frog said:
Cheers Stu
Cheers
Ian
 Not far away is the Cinderella club at Hoar Park - any time from 10:00 ‘til 13:00 Tomorrow you will find an eclectic mix of bikes & bikers.
If you fancy a meet up, I’ll be there.
It is also a tag 👍
Edited by Mickly
That's known as a Mechanical Seal . Have you tried Chinese Bike Parts ( Something like that ) it's probably fairly generic .
  • Like 2
Thats poo 🙄
12 hours ago, Ian Frog said:
Cheers Stu
Cheers
Ian
Yes please do a thread for this 🥰
Good luck 🤞
  • Thanks 1
Yeah I found out it's name from some searching, unfortunately they are out of stock it is a generic part and fits some current Lexmoto models, just none available.
I will phone them tomorrow and find the general specs and then see if I can get an equivalent part from some where else, there can't be that many variations so logically I should be able to find one :thumb:
10 hours ago, gymwitch said:
Good luck 🤞
Well it didn't work but it was worth trying as nothing lose :thumb:
What does this little thing do or not do now
It's part of the water pump it fits behind the impeller, I assume it's to prevent the coolant going into the engine block, but when it starts to fail there is a weep hole which allows fluid to vent to the outside as an indicator that something is amiss, like with mine which was split.
Ahh gotcha now.
Just been looking on ebay and there are quite a few and all i need to replace is the spring part, watched a video and the guy kept his original metal piece and just replaced the spring and the bit in the impeller, so might take a punt on a couple of the ebay ones tomorrow and see if any will fit :thumb:
it prevents both
Oil mixing with water and water mixing with oil :thumb:
https://www.racing-planet.co.uk/water-repair-minarelli-generic-keeway-motobi-1e40ma-1e40mb-p-177257-1.html?utm_source=google&utm_medium=google_merchant&utm_campaign=google_products&gclid=Cj0KCQjwzYGGBhCTARIsAHdMTQz-DmKw8EbSaxvVsKCyG2DJCwsE227du4M6lGzd1a3e5A32SQA7_zsaAsd0EALw_wcB#.YMEfObfTUvo
Is that one on the card ?
That's a full repair kit I just need the springy rubber bit, going to try a local bike shop first tomorrow as they might have one, they do a lot of oddball items.
I also have another problem now, on the oil filter cover one of the bolt holes has stripped the threads and can't get it tight enough to seal properly.
I was thinking about using an epoxy resin and bonding in some studs and use dome nuts instead of bolts, good or bad idea otherwise it would mean retapping and run the risk of breakout.
It's 8quid 😂
Think I would be tapping out next size up, proper thread lock and setting studs in
4 minutes ago, Bender said:
It's 8quid 😂
The one that's stripped there is an alignment tube which would make tapping out a bit more difficult, hence my reason just to go with bonding in a stud.
