Liveware Problem Posted December 13, 2018 Share Posted December 13, 2018 Got my bike out ready to go to work, left it on the side stand whilst I turned back to close and lock the gate and heard a loud crunch.. Oh it won't be too bad, I thought (hoped), maybe just a few cracks and scratches on the fairing.. So basically the fairing sheared off almost all the fixings, and is broken all the way through either side of the headlight, and the part either side of the clocks has broken, as well as the metal support holding the dash/clocks to the yoke shearing off (last pic)It's completely unrideable. I haven't looked yet but I have a nasty feeling it will cost a small fortune to repair that sort of damage Any advice would be much appreciated! Quote Link to comment Share on other sites More sharing options...
mikestrivens Posted December 13, 2018 Share Posted December 13, 2018 Oh dear. Sorry to see that. Quote Link to comment Share on other sites More sharing options...
Edd80 Posted December 13, 2018 Share Posted December 13, 2018 Nightmare!!Looks like you know what to ask santa for now Quote Link to comment Share on other sites More sharing options...
Six30 Posted December 13, 2018 Share Posted December 13, 2018 Shite .... Was side stand not down properly ? Quote Link to comment Share on other sites More sharing options...
goat Posted December 13, 2018 Share Posted December 13, 2018 Horrible. What made it fall over, did it roll forward a bit or something? Quote Link to comment Share on other sites More sharing options...
learningtofly Posted December 13, 2018 Share Posted December 13, 2018 Damn! having had a couple of awkward moments with regard to the sidestand myself, I really feel for you. Quote Link to comment Share on other sites More sharing options...
Via Posted December 13, 2018 Share Posted December 13, 2018 Not good! Surprised at metal bracket going, tbh fairing can be so flimsy it breaks from just being removed so don't expect that to look good but would expect the metal supports to survive Quote Link to comment Share on other sites More sharing options...
TimR Posted December 13, 2018 Share Posted December 13, 2018 check headstock steering stops as early triumph used to be made of cheese ( the part that stops the steering turning all the way round ) Quote Link to comment Share on other sites More sharing options...
TimR Posted December 13, 2018 Share Posted December 13, 2018 as its on its right side i doubtbsidestand as its down in picture . either just over balance point on kerb camber or quite windy combined with balance point Quote Link to comment Share on other sites More sharing options...
raesewell Posted December 13, 2018 Share Posted December 13, 2018 The cost of the repair could well exceed the value of the bike, ouch Quote Link to comment Share on other sites More sharing options...
Slowlycatchymonkey Posted December 13, 2018 Share Posted December 13, 2018 Noooo. Sorry to see that. Hope it not as painful as you think (or it looks) £££ Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted December 13, 2018 Author Share Posted December 13, 2018 as its on its right side i doubtbsidestand as its down in picture . either just over balance point on kerb camber or quite windy combined with balance point Yep. It's my fault. I park it facing out so I can lock the back wheel to my scooter's back wheel, but that means when I get it out I have to manoeuvre it to the left, which means it's leaning against the camber of the pavement. I usually check to see if it moves when I get off but I didn't this morning and it must have slipped slightly and then overbalanced.[mention]raesewell[/mention] yes I'm thinking that's likely :/ Quote Link to comment Share on other sites More sharing options...
Fleck Posted December 13, 2018 Share Posted December 13, 2018 Can you turn it into a naked street fighter or something? Then sell it as a unique bike, somebody will love it Quote Link to comment Share on other sites More sharing options...
Bender Posted December 13, 2018 Share Posted December 13, 2018 If you go down insurance route that's prob going to get written off, you may be able to keep it for a fee and fix it yourself and not be out of pocket, insurance no doubt will increase. Quote Link to comment Share on other sites More sharing options...
Fleck Posted December 13, 2018 Share Posted December 13, 2018 I wouldn't claim on the insurance, you'll be paying for it for years to come. Even if your ncb is protected you'll have to declare a claim in the last 5 years and the policy cost will increase. Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted December 13, 2018 Share Posted December 13, 2018 It's fixable!Remove sheared studs (may need a small extractor if not enough showing to get a grip on).Complete set of replacement fixings <£50Fairing can be repaired - Glued with a decent fibre-based resin, filled, sanded and re-painted <£200Bike is worth at least £450 Go for it!'Winter Project' Quote Link to comment Share on other sites More sharing options...
Liveware Problem Posted December 13, 2018 Author Share Posted December 13, 2018 (edited) It's fixable!Remove sheared studs (may need a small extractor if not enough showing to get a grip on).Complete set of replacement fixings <£50Fairing can be repaired - Glued with a decent fibre-based resin, filled, sanded and re-painted <£200Bike is worth at least £450 Go for it!'Winter Project' Thanks GoG, I do appreciate you advice Unfortunately I described it badly, the studs are fine it's the connecting plastic that's broken, no way to repair those small pieces properly.Also the last photo shows where the metal support for the clocks has shorn, I don't think I could glue that! The entire front of the bike is almost free-floating right now.Coupled with the fact I have no idea how to do any of the things you described, and have nowhere to work on the bike!I'm taking it to the local motorbike shop to see what their mechanics make of it. Edited December 13, 2018 by Liveware Problem Quote Link to comment Share on other sites More sharing options...
JRH Posted December 13, 2018 Share Posted December 13, 2018 That's not good, hope it can be repaired at not too much cost. Quote Link to comment Share on other sites More sharing options...
Arwen Posted December 13, 2018 Share Posted December 13, 2018 Ouch! Hope you can get it sorted without too much hassle. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted December 13, 2018 Share Posted December 13, 2018 That's a horrible thing to happen, all the worse for being such a simple accident. I have in the past mended small plastic brackets using finger bandage and epoxy resin. It's a trick I learnt making components for model aircraft. It's usually better to actually make a whole new bracket than repair the broken one. The thing is to spread the pressure area where it connects to the main body of the fairing. Quote Link to comment Share on other sites More sharing options...
fastbob Posted December 13, 2018 Share Posted December 13, 2018 Ouch indeed, sorry to hear about your unfortunate event . My first reaction was to see what body work was on eBay . There is some but its all blue . I guess you could still get some and get it sprayed to match . If you repair the existing panels they will still have to be painted so this route might be cheaper and less hassle. Quote Link to comment Share on other sites More sharing options...
TimR Posted December 13, 2018 Share Posted December 13, 2018 didnt someone on here recently build a 3d printer ........ Quote Link to comment Share on other sites More sharing options...
bonio Posted December 13, 2018 Share Posted December 13, 2018 Oh nooooooooThat is so miserable Sorry, clean out of helpful advice. But you clearly need a hug I learned this here: So here's a selection. All you have to do is pick the hug you're most comfortable with. And you don't have to tell us which - it's your secret. Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted December 13, 2018 Share Posted December 13, 2018 Crap,been there done that.Dropped the FZR on the floor, thought the stand was down Araldite rapid is good for fixing some types of plastic.The bodywork on the RGV needed some repairs on the mounting lugs and 4 years later are still good Quote Link to comment Share on other sites More sharing options...
Via Posted December 13, 2018 Share Posted December 13, 2018 I take it clips are hidden when affixed, I'd plastic weld them, that's what I did for ER5 and stronger than original.Use some thick single strand copper wire (or even a staple) and fold so you have an S shape and melt into the plastic across the crack. You can get plastic filler rods on eBay or use cable ties. Most common mistake is people overheat the plastic making it brittle, you want lowest temp plastic melts at (normally 210°c is good).Plenty of example videos on YouTube. Quote Link to comment Share on other sites More sharing options...
