Turbogirlie Posted August 17, 2021 Posted August 17, 2021 Don't spill E10 on any paintwork which isn't lacquered.....as it acts as a paint stripper... Took the tank off the GT to check the coils and fuel leaked from the tap over the gearbox casing...not a happy person now. Worse than brake fluid. 1 3 Quote
Turbogirlie Posted August 17, 2021 Author Posted August 17, 2021 I'm not a chemist, but have gathered that the increase in ethanol is the problem...and it can dislodge any debris in the tank & cause fuelling issues due to blocked jets.......... Quote
oldgrump Posted August 17, 2021 Posted August 17, 2021 1 hour ago, Turbogirlie said: I'm not a chemist, but have gathered that the increase in ethanol is the problem...and it can dislodge any debris in the tank & cause fuelling issues due to blocked jets.......... Hi @Turbogirlie, don't think your GT750 would be compatible with E10 fuel!! Bit to old, I may be wrong, but I would be very wary of using it. Quote
fastbob Posted August 18, 2021 Posted August 18, 2021 Don't worry me none , a Harley Davidson with run on Kentucky Bourbon , yes siree Bob . 2 Quote
Mickly Posted August 18, 2021 Posted August 18, 2021 17 minutes ago, fastbob said: Don't worry me none , a Harley Davidson with run on Kentucky Bourbon , yes siree Bob . Bloody expensive/ Best set up your own moonshine still - it can’t be hard, look at the Rednecks that do it on the tele, not a shared brain cell between them !! 1 1 Quote
Bender Posted August 18, 2021 Posted August 18, 2021 21 minutes ago, fastbob said: Don't worry me none , a Harley Davidson with run on Kentucky Bourbon , yes siree Bob . Better to drink it and look at the bike. 1 Quote
Turbogirlie Posted August 18, 2021 Author Posted August 18, 2021 9 hours ago, TimR said: https://www.gov.uk/check-vehicle-e10-petrol 19 hours ago, oldgrump said: Hi @Turbogirlie, don't think your GT750 would be compatible with E10 fuel!! Bit to old, I may be wrong, but I would be very wary of using it. The link really is useless (have checked this out before) so don't know why the government put that up as it basically says, check with the manufacturer. As for compatibility - I seriously doubt that this stuff is any good for any vehicle, as it will drag all the crud out of a tank through the fuel system...even on a modern vehicle. Just don't spill it on paintwork which isn't fuel proof... Quote
Mississippi Bullfrog Posted August 19, 2021 Posted August 19, 2021 I put some in my 2006 Honda....and it ran. 2 Quote
dynax Posted August 19, 2021 Posted August 19, 2021 14 hours ago, fastbob said: Don't worry me none , a Harley Davidson with run on Kentucky Bourbon , yes siree Bob . Diesel doesn't work too good in them as one of our group found out last night Quote
geofferz Posted August 19, 2021 Posted August 19, 2021 17 hours ago, Turbogirlie said: The link really is useless (have checked this out before) so don't know why the government put that up as it basically says, check with the manufacturer. As for compatibility - I seriously doubt that this stuff is any good for any vehicle, as it will drag all the crud out of a tank through the fuel system...even on a modern vehicle. Just don't spill it on paintwork which isn't fuel proof... Really? Quote
geofferz Posted August 19, 2021 Posted August 19, 2021 I have always taken serious care not to spill petrol on any part of my bike. Quote
TimR Posted August 19, 2021 Posted August 19, 2021 Your older vehicle will still run on e10 but it has the potential to dissolve the fuel lines and seals slowly . Creating the risk of a leak and potential fire and risk of poor engine performance . Quote
Turbogirlie Posted August 22, 2021 Author Posted August 22, 2021 On 19/08/2021 at 13:47, geofferz said: Really? When I tried this for my bike it advised me to ask the manufacturer. I am glad you got a better result than I. No offence was intended, just found the link itself to be vague when I used it before. 1 Quote
billy sugger Posted September 11, 2021 Posted September 11, 2021 While I can get it I'm using the 97 octane unleaded as that is remaining as e5. Ethanol is hydroscopic, so will attract water to it, so if using e10 and sorning your bike for winter make sure you drain your tank Quote
Mississippi Bullfrog Posted September 24, 2021 Posted September 24, 2021 Honda have some helpful advice for those running outboard engines. Buy a new engine. 1 Quote
SloRider125 Posted September 24, 2021 Posted September 24, 2021 After rebuilding my Honda, I filled with that E10 watered down crap... the bike runs, but it doesn't like any throttle... Now I'm reading that E10 is no good for Carb'd bikes... so after rebuilding the carb, i'll top it off with Super Unleaded. Quote
KiwiBob Posted September 24, 2021 Posted September 24, 2021 23 minutes ago, SloRider125 said: After rebuilding my Honda, I filled with that E10 watered down crap... the bike runs, but it doesn't like any throttle... Now I'm reading that E10 is no good for Carb'd bikes... so after rebuilding the carb, i'll top it off with Super Unleaded. If your bike is running badly after a rebuild it won't be E10 fuel that is the problem! Quote
Davidtav Posted September 24, 2021 Posted September 24, 2021 I can’t honestly say I’ve noticed any difference with how my bike runs. Or the car. However the exhaust down pipes had a slight blue tinge. And that is becoming more noticeable. Might have nothing to do with E10 at al. But I’m thinking that the bike might be running even more lean. And they seem to be set up lean anyway to get through emissions regulations. Quote
SloRider125 Posted September 24, 2021 Posted September 24, 2021 6 minutes ago, KiwiBob said: If your bike is running badly after a rebuild it won't be E10 fuel that is the problem! Yep my carbs need Jetting... but still dont trust that watered down crap Quote
Mississippi Bullfrog Posted September 24, 2021 Posted September 24, 2021 56 minutes ago, SloRider125 said: After rebuilding my Honda, I filled with that E10 watered down crap... the bike runs, but it doesn't like any throttle... Now I'm reading that E10 is no good for Carb'd bikes... so after rebuilding the carb, i'll top it off with Super Unleaded. My Honda runs fine on E10. The Triumph is also fine. In fact it seems to run better on E10 than premium E5. Quote
skyrider Posted September 25, 2021 Posted September 25, 2021 i will keep putting E5 in my lawnmowers then Quote
husoi Posted October 8, 2021 Posted October 8, 2021 I wonder if this could be a way around it. just not sure if I want to spend all that time in this process unless when storing the bike for winter as alternative to remove all the fuel from the tank and put it back when I go on a ride. Quote
Mississippi Bullfrog Posted October 8, 2021 Posted October 8, 2021 57 minutes ago, husoi said: I wonder if this could be a way around it. just not sure if I want to spend all that time in this process unless when storing the bike for winter as alternative to remove all the fuel from the tank and put it back when I go on a ride. Why bother? If you're worried just fill with premium E5 before laying it up. I've never had any issue with E5 left over the winter. 3 Quote
